• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor hlo
    Valued Contributor
    Accepted Solution
    Save as - Drawing to PDF and JPG
    204 Views, 3 Replies
    01-08-2013 09:55 PM
    Hi
    I need to convert a idw drawing to PDF and JPG, when save to PDF there are no problems
    but when I do it for JPG it seem to be a screen dump and not similar to the PDF I only need the drawing exact as the PDF. Is there a way for this.
    Regard
    Henrik
    Please use plain text.
    *Expert Elite*
    sam_m
    Re: Save as - Drawing to PDF and JPG
    01-09-2013 12:29 AM in reply to: hlo
    I use PDFCreator as my pdf-printer (previously found Inventor's own pdf-creation tools less than fantastic so have just stuck with a pdf-printer) - it has the ability to "print" to an image format as well as pdf, so it will create a jpg exactly the same as the pdf printout.  Might be worth giving it a try?
    Please mark this response as "Accept as Solution" if it answers your question - but note that the solution may not be the answer you're wanting to hear...
    Lithium - helping nntp users with mania, depression and headaches
    Valued Contributor
    01-09-2013 09:05 PM in reply to: sam_m
    HI, I thanks for replaying, hopefully AutoDESK are correcting this feature in the future
    Regards
    Henrik
    *Expert Elite*
    sam_m
    01-10-2013 12:23 AM in reply to: hlo
    dumb question - why do you mark your own answer as the solution?  it's not, so why do it?  (kinda seems like a bug/exploit in the forum software if you're able to mark your own answer as a solution)
    whether it's right of wrong the jpg/image output has always been a snapshot of the screen and not linked to the print-result.  It includes the background colour plus the sheet-colour in idw environment and the xyz triad in modelling environment.  Can just use an image-editing tool to crop the desired portion of the image if it's unsuitable.
