Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Save PDF using iLogic and name after revision number?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello!
My question: We want to use iLogic to save a PDF-file of the DWG-drawing every time we hit "save". We now use the following iLogic code:
Question 1: Is it possible to save the PDF in a new folder that lies "one step up". For example: My DWG-file is placed in c:/drawings/thing4/DWG, I want the PDF to end up in c:/drawings/thing4/PDF. If I am in folder "c:/drawings/thing2/DWG" I want the PDF to end up in "c:/drawings/thing2/PDF" etc. Possible?
Question 2: My DWG files is named "thing4.dwg" and it is the 2nd revision. I want the PDF-file to be named
"thing4 Ed2.pdf". Possible?
Any help would be very appreciated!
/Gustav
Re: Save PDF using iLogic and name after revision number?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
1. Yes you can. You will just need to use a different path instead of oPath in this line: oDataMedium.FileName = oPath & "\" & PN & ".pdf" 'Publish document
2. Yes this is possible. You will need to get the revision of the file using iProperties.value("Project, "Revision Number") and set it as a variable. Then in your code when you give the PDF the file name, you will need to append that to the file name.
So what you want to do can be done.
BTW, this question may be best in the Inventor Customization forum.
Dan
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi GustavStigsohn,
You can find an example rule at this link:
http://inventortrenches.blogspot.com/2011/07/ilogi
I hope this helps,
Best of luck to you in all of your iLogic and Inventor pursuits,
Curtis
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Big thanks to you both! It works like a charm.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Curtis,
I tried the iLogic code from your link, and it works very well. I was able to modify the code to suit our pdf file naming conventions. Do you know how to change the code to get it to save a drawing to AutoCAD.dwg (2004) format as well?
We also have quite a few Inventor drawings that have multiple drawing sheets per drawing file.
The drawing number for each sheet is taken from the Part Number field of the part or assembly detailed on that sheet. These different sheets have individual revisions, which is driven by the <Sheet Revision> property.
So we have an Inventor drawing file like this:
ABC-123.dwg, which contains drawing numbers:
ABC-123-01, ABC-123-02, ABC-123-03 etc.
It would be a real time saver if we could export all sheets in one iLogic rule to separate PDF's, i.e.:
ABC-123-01rev2.pdf
ABC-123-02rev1.pdf
ABC-123-03rev0.pdf
I'm only just starting out with iLogic so am not yet equipped to take your code and customize to suit my needs.
Appreciate any help!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi DCDM,
Here is an example rule that tranlsates an Inventor drawing to an AutoCAD 2004 DWG.
I hope this helps.
Curtis
'------- start of iLogic code -------------------
' Get the DWG translator Add-In.
Dim DWGAddIn As TranslatorAddIn
DWGAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
'Set a reference to the active document
Dim oDocument As Document
oDocument = ThisApplication.ActiveDocument
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslation Context
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
' Create a NameValueMap object
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMa p
' Create a DataMedium object
Dim oDataMedium As DataMedium
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
' Check whether the translator has 'SaveCopyAs' options
If DWGAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
' DWG version.
' 23 = ACAD 2000
' 25 = ACAD 2004
' 27 = ACAD 2007
' 29 = ACAD 2010
oOptions.Value("DwgVersion") = 25
Dim strIniFile As String
strIniFile = "C:\temp\DWGout.ini"
' Create the name-value that specifies the ini file to use.
oOptions.Value("Export_Acad_IniFile") = strIniFile
End If
'get path and file name
path_and_name = ThisDoc.PathAndFileName(False) ' without extension
'Set the DWG target file name
oDataMedium.FileName = path_and_name & ".DWG"
DWGAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
'------- end of iLogic code -------------------
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi DVDM,
Here is a rule that will write out each sheet to a PDF following the naming scheme you mentioned. But I wasn't able to find the hook to use the Sheet Revision property. Maybe someone will have a look and point us to it. In the mean time this should get you started.
I hope this helps.
Curtis
'------start of iLogic-------
oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
'Define the drawing
Dim oDrawing As DrawingDocument
oDrawing = ThisDrawing.Document
'Count the sheets
Dim intNumSheets As Integer
intNumSheets = oDrawing.Sheets.Count
Dim intIndex As Integer
For intIndex = 1 To intNumSheets
If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 1
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintSheetRange
oOptions.Value("Custom_Begin_Sheet") = intIndex
oOptions.Value("Custom_End_Sheet") = intIndex
End If
'get PDF target folder path
oFolder = Left(oPath, InStrRev(oPath, "\")) & "PDF"
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
End If
'Set the PDF target file name
oDataMedium.FileName = oFolder & "\" & oFileName & "-0" & intIndex & ".pdf"
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Next
'------end of iLogic-------
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Curtis,
Thanks for those, very much appreciated!
I've tested both, and both work pretty well, but would like to do a bit of finetuning, and ask you a few more questions.
The save to dwg rule doesn't seem to save to Acad 2004 format, but to 2010 format (which is the default setting for the exporter), so it ignores the Options.Value setting from your rule. I checked by looking at the file header which is AC1024, which should be AC1018 for Acad 2004 format.
Your rule packs the drawings into a zip file, but by default this 'pack and go' option is unticked. So the questions is, how are these options controlled? Does the C:\temp\DWGout.ini file play a role in this? I don't actually know what this file currently does, or how to store configuration settings in it if possible.
The one other niggle is that during the export the filename gets the addition of a _ in the filename (i.e. ABC-123_-01.DWG), but as it's done by the built in exporter and not the rule that invokes it this might not be possible to change?
Your export to pdf works very well, but would like to finetune the naming convention. For example:
ABC-123.dwg contains:
ABC-123-01, ABC-123-02, ......, up to ABC-123-99
This currently saves out to ABC-123-01, ABC-123-02,......, ABC-123-099. You add the "-0" to the filename, but after 10 sheets the "-0" should no longer apply.
But this is only when we have a fully sequential set of sheets without any gaps.
Say we have a 3 sheet drawing like this:
ABC-123-05, ABC-123-10, ABC-123-34
This currently saves out to ABC-123-01, ABC-123-02, ABC-123-03.
This could be solved two different ways. The way the "Export to dwg" tool does it would work quite well, by using the sheet name. We name our sheets like this: -05, -10, -34, so in the model tree for the drawing you see: -05:1, -10:2, -34:3. If this value could be used to append the filename that would be the most straightforward fix.
The drawing number also matches the part number of the component detailed. The title block picks up the <Part Number> value of the model, so this one drawing file with 3 sheets would be detailing ABC-123-05.iam, ABC-123-10.ipt & ABC-123-34.ipt.
Since a sheet can contain many base views to different parts and assemblies you wouldn't be able to establish which one to use, unless it would be able to pick it based on the first view placed, similar to how the title block knows to pick to <Part Number> from the first view.
I've only just started learning how to use iLogic last week, so wouldn't be able to write anything this complex with VB in it. Reading through the code I'm able to get an idea what's going on, and can imagine being able to do something like that once I know VB myself. One thing that puzzles me though is the
ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")code. Where are you supposed to find something like that?
Appreciate your help!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I figured out how to get that ini file to work:
http://forums.autodesk.com/t5/Autodesk-Inventor-Cu
So I'd be able to set up different ini files, that are called upon by different iLogic rules, that'll be pretty handy.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi DVDM,
Let's focus on just the PDF part of this for now and come back to the DWG export. If I understand correctly, this rule should output the PDF's per sheet as such:
A drawing has 3 sheets:
ABC-123-05:1
ABC-123-10:2
ABC-123-34:3
the rule writes out 3 PDF's:
ABC-123-05.pdf
ABC-123-10.pdf
ABC-123-34.pdf
and places them in a folder named PDF that resides next to the drawing file:
C:\Temp\ABC-123-05.dwg
C:\Temp\PDF\ABC-123-05.pdf
C:\Temp\PDF\ABC-123-10.pdf
C:\Temp\PDF\ABC-123-34.pdf
Let me know if this is what you're after.
I hope this helps.
Curtis
'Define the drawing
oDrawing = ThisDoc.Document
Dim oSheet As Sheet
Dim lPos As Long
Dim rPos As Long
Dim sLen As Long
Dim sSheetName As String
Dim sSheetNumber As String
'step through each drawing sheet
For Each oSheet In oDrawing.Sheets
'find the seperator in the sheet name:number
lPos = InStr(oSheet.Name, ":")
'find the number of characters in the sheet name
sLen = Len(oSheet.Name)
'find the sheet name
sSheetName = Left(oSheet.Name, lPos -1)
'find the sheet number
sSheetNumber = Right(oSheet.Name, sLen -lPos )
'set PDF Options
oOptions.Value("Custom_Begin_Sheet") = sSheetNumber
oOptions.Value("Custom_End_Sheet") = sSheetNumber
End If
End If
oDataMedium.FileName = oFolder & "\" & sSheetName & ".pdf"
'Publish document
Next
