• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    Active Member
    Save Error
    790 Views, 5 Replies
    08-03-2010 03:36 PM
    After placing a new component into an assembly I pressed save and a dialog box came up "File Copy on Save" Access is denied. Run into any other problems like this?
    Inventor 2011 Professional
    Please use plain text.
    Product Support
    Re: Save Error
    08-05-2010 12:46 PM in reply to: SpitfireRcp
    Please supply a screen capture of the error message dialog box. This sounds like permissions. A save is a multi-part process where it saves a temporary lock file, saves the file to the location (non-read only location), and finally releases the .lck file. Are you saving locally or to a network location? Please also supply your ipj file as this could be very useful in troubleshooting as well. Thank you.
    Daren Lawrence
    Product Support Specialist
    MFG Support - Inventor
    http://beinginventive.typepad.com/being-inventive/
    Re: Save Error
    08-05-2010 01:34 PM in reply to: Daren.Lawrence
    I am experiencing a lot of similar trouble with 2011.
    I have been using Inventor for several years - no change in workflow from earlier releases.
    Saving locally to same location as active Profile.
    I will post screen shots next time it happens.
    Re: Save Error
    08-05-2010 01:41 PM in reply to: JDMather
    Here is my workflow that results in error.
    Someone posts a file here with a question.
    I  File>Save As and make changes.
    Make additional changes and save frequently.
    At some point after working for a while and saving frequently I get the two error messages shown in attached.
    Inventor creates a *.newVer.ipt
    New Member
    tormond
    Re: Save Error
    11-30-2010 10:28 AM in reply to: JDMather
    JD,
    Wondering if you ever fixed the problem you were having...I am getting the same error messages when my students try to save an assembly file they have recently changed. IF, they are able to save, it adds .newver to the file name and then they can't open the file.
    I can't seem to figure out what is happening and several of my students are having this same issue.
    Any help is appreciated!
    Tracey
    Active Member
    Re: Save Error
    11-30-2010 12:17 PM in reply to: tormond
    Tracey,
    I believe all that you have to do is change the extension ".newver" to .iam
