• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    Valued Contributor
    SW to IV translation failing
    28 Views, 7 Replies
    11-07-2002 05:28 AM
    I have a huge (~55Mb) assembly I need to get from SW to Inventor. Since I don't care how "smart" it is, I first tried IGES. But after it came in, there were a lot of unstitched bodies. When I tried to stitch & promote (auto stitch & promote didn't work) I got incomplete parts and surfaces. I know the SW parts are complete solids, so I'm not sure why it did this. Nest, I tried STEP. I wasn't sure of the difference, so I tried both formats (203 & 214), but SW doesn't actaully export anything. What I mean is it doesn't create a file. So now I'm trying to save as a Pro/E file, and import to Inventor that way. Any advice?
    Please use plain text.
    *DJSpaceMouse
    Re: SW to IV translation failing
    11-07-2002 05:36 AM in reply to: davej
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    Any advice?
    Valued Contributor
    Re:
    11-07-2002 06:03 AM in reply to: davej
    I went to their site. I saw that they have a CADporter for SW to INV, but can't find the d/l anywhere on their site. This is kind of a hurry-up job, so I don't think I can wait for them to ship me a CD. Any other ideas.
    *Cook, Gary
    11-07-2002 06:07 AM in reply to: davej
    I suggest you try the step files again, something odd is going on there.
    Actually the first thing you should try should be to export the assy as an
    acis (*.sat) file, version 6.0.
    Failing that, try a conversion company, but that may be pricey.
    "davej" wrote in message
    news:f1211c5.-1@WebX.maYIadrTaRb...
    *Corbin, Brian
    Re:
    11-07-2002 06:29 AM in reply to: davej
    Dave
    In SW Export as ACIS file (*.SAT)
    In INV open *.SAT file
    Usally gives 100% solids but no
    intelligence....
    Brian
    I
    ideas.
    *Howard, Jeff
    11-07-2002 09:05 AM in reply to: davej
    Have you tried the SW group? Sounds like there may be a problem on that end
    (no stp written). You might also consider breaking it into smaller assemblies
    if it's feasible. You may at least be able to isolate a problem area.
    Jeff
    way. Any advice?
    *Bliss, Charles
    11-07-2002 11:52 AM in reply to: davej
    55 megabytes is not a huge assembly. It sounds like there is something
    wrong on your end. Check for free disk space, swap file size etc.
    Elysium will have trouble with the file is SolidWorks does so before
    sending it Elysium, try to get a STEP file out as a test at the minimum.
    You will want to try AP214 CD.
    *Hiebert, Billy
    Re:
    11-08-2002 12:29 AM in reply to: davej
    Acis is what I've always used from SW to MDT or Inv. But lately they
    have been coming in with many errors. Trying to export an STL from them
    now is unusable. It may be just a fluke, but knowing the past history
    of SW,s marketing practices, it could be their latest...Probably my
    paranoia.
    Billy Hiebert
    HIEBERT SCULPTURE WORKS
    Small Part Injection Molding
    http://www.hieberts.com
    Brian Corbin wrote:
    > Dave
    > Usally gives 100% solids but no intelligence....
    > Brian
    > "davej" > wrote
    > in message news:f1211c5.1@WebX.maYIadrTaRb...
