• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    mariappan.u
    STP FILE SHEETMETAL FLAT PATTERN
    236 Views, 6 Replies
    12-06-2011 02:32 AM
    Hi all,
    I have stp file to convert sheetmetal flat pattern.i can convert some portion but i cant convert particular portions.
    see attached file.
    waitng for solution.
    Please use plain text.
    *Expert Elite*
    Re: STP FILE SHEETMETAL FLAT PATTERN
    12-06-2011 04:43 AM in reply to: mariappan.u
    You might be waiting a while - of course Inventor will not unfold a jpg image.
    You will need to attach the ipt file here.
    Active Member
    mariappan.u
    12-06-2011 08:00 PM in reply to: JDMather
    I CANT ATTACH STP FILE IN THIS FORUM
    *Expert Elite*
    12-07-2011 04:09 AM in reply to: mariappan.u
    Right click on the file name and select Send to Compressed (zipped) Folder
    and attach the resulting *.zip file here
    or
    attach the translated *.ipt file here.
    Active Member
    mariappan.u
    12-08-2011 05:20 PM in reply to: mariappan.u
    here is the attachment.
    *Expert Elite*
    12-09-2011 05:05 AM in reply to: mariappan.u
    If you look in this area from the right side this face (and I assume the opposite face) is warped.
    This was hard to see from the jpg you originally posted.
    You will have to Delete Face and rebuild that area of the part.
    *Expert Elite*
    12-09-2011 06:56 AM in reply to: JDMather
    Considering manufacturing tolerance - perhaps this is close enough.
