• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    czoobs
    STL - can I export only surfaces?
    941 Views, 14 Replies
    08-06-2010 11:39 AM
    Hello Inventor users,
    I'm wondering if there is a possiblity in Inventor to export a surface model as a STL file. I use CAD programs to prepare models for simulations in other software and I would like to work with Inventor because my Depratment uses it. Till now I have been using SolidWorks and with a little trick it is possible to export surfaces as a STL file. In Inventor I didn't manage to do this. So, is it possible?
    Best regards,
    Wojek
    Please use plain text.
    Valued Mentor
    jclaidler
    Re: STL - can I export only surfaces?
    08-06-2010 11:51 AM in reply to: czoobs
    STL is an export option for Inventor 2011.
    _______________________________________________________________
    ITO - Application Management
    Factory Design Suite Ultimate 2012
    AutoCAD 2012 | Inventor Professional 2012 | Vault Professional 2012
    *Expert Elite*
    08-06-2010 12:42 PM in reply to: czoobs
     Wojek
    I don't think it is possible to export surface bodies as stl in Inventor.
    AFAIK only solid bodies are supported for stl export.
    (Of course the exported stl is all surfaces as stl is a surface definition format.)
    Employee
    08-08-2010 07:40 PM in reply to: czoobs
    Wojek,
    It's not feasible for Inventor to export surface data as STL.
    Why not use other formats instead? IGES/STEP/Parasolid?
    Also if available, please share me more information about your workflow and request. We may consider the surface export in STL later.
    Austin
    Zongjie Liu
    Zongjie.Liu@autodesk.com
    Software Quality Assurance
    Design, Lifecycle & Simulation
    Autodesk, Inc.
    Member
    czoobs
    08-09-2010 07:52 AM in reply to: czoobs
    Thank you for your answers.
    As I mentioned before I use CAD programs to prepare models for my simulations. To be precise, I simulate work of bulk handling machines and devices with the Discrete Element Method. In these simulations it is advisable to use simplified geometry because of the character of the calculating process. In many cases I need only one side of, for exemple chute wall, and surface is far enough. For now I can only import STL geometry and that is why I asked about this format.
    I would like to use Inventor because my department uses it and there wouldn't be any problems with data exchange.
    Distinguished Mentor
    08-09-2010 08:56 AM in reply to: czoobs
    Buy a seat of Rhino 3D, about $1000
    Export from IV to Rhino as stp
    Save as stl in Rhino
    JD,
    FYI, stl is polygon mesh, not surfaces
    Member
    czoobs
    08-09-2010 10:09 AM in reply to: czoobs
    Yes I know what STL is :smileywink:
    The way you suggested...this is not a good solution. Maybe I'll just stay with SolidWorks
    Valued Mentor
    jclaidler
    08-09-2010 10:11 AM in reply to: czoobs
    Try creating a 'level of detail' that only has surfaces, then export as an STL.
    *Expert Elite*
    08-09-2010 10:45 AM in reply to: jclaidler
    Can you attach example files of this workflow?
    New Member
    grv19191
    07-15-2011 12:59 AM in reply to: czoobs
    I am having problems with saving some surfaces as STL in solidworks. Please help me with how can i save as stl in solidworks.
