• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    SQL search from Ilogic
    336 Views, 3 Replies
    01-14-2010 06:06 AM
    Is it possible to make a SQL database search and write from an Ilogic rule?
    /Lars
    Valued Mentor
    Mike.Wohletz
    Re: SQL search from Ilogic
    01-14-2010 07:49 PM in reply to: srpack
    I would think that this would be possible since ILogic has the ability to run straight vb code. It does look like something that I would do when I could create a DLL to do the work for me and return back to ILogic the required info.
    Employee
    01-15-2010 03:43 AM in reply to: srpack
    Yes, this is exactly right. It's reasonably straightforward to incorporate the use of ADO.NET into your rules to add database access. We haven't yet delivered samples on this, but others in the community have done this, and I'm sure could provide some examples of what they've done.
    Jeff
    09-09-2010 02:19 AM in reply to: srpack
    I am also trying to read data from an SQL file.   I have written a DLL which is accessed from iLogic using the AddReference command When I try to use the rule I get the error "The 'Microsoft.Jet.OLEDB.4.0' provider is not registered on the local machine" when I call the read SQL function in the DLL.
    The code was originally written in the ipart in VBA and worked without any problems.
    Can anyone help, or give an example of what I should do?  Is there something I should be registering?
    Alistair
