• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Accepted Solution
    Rubber Track Design
    375 Views, 16 Replies
    01-09-2013 07:17 PM
    Trying to model a track but i have it in more of a triangular orientation then an ovel like this sample picture. Any advice on how to pattern the tread and inner lug around any shape i desire? I have tried making an extrusion on one of the flat faces and then patterning it around but it keeps the lug in the same orientation and does not follow the contour nicely. Any advice for me
    Please use plain text.
    Active Contributor
    Re: Rubber Track Design
    01-09-2013 11:36 PM in reply to: mklassen78
    You can do rectangular pattern in part enviroment along choosen curve, and set orientation to direction1. This should work.
    I hope that's what you're looking for.
    Greg
    Factory design suite 2013 premium
    Some old workstation ...
    Fancy HP LCD
    :smileyhappy:
    *Expert Elite*
    01-10-2013 04:42 AM in reply to: mklassen78
    mklassen78 wrote:
    Trying to model a track but i have it in more of a triangular orientation . Any advice for me?
    See this document pg 16
    http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
    Member
    01-10-2013 06:19 PM in reply to: JDMather
    Thank you for your replies! JDMather that does work to pattern around and i can get it to follow the contour i want but it leaves a gap between the "treads" as it is patterned around a curve. It does not keep tangent. Any solution to that?
    *Expert Elite*
    01-10-2013 06:55 PM in reply to: mklassen78
    Attach your ipt file here.
    Member
    01-10-2013 08:21 PM in reply to: mklassen78
    Hope this helps more
    *Expert Elite*
    01-11-2013 04:47 AM in reply to: mklassen78
    I don't see a pattern in the file you attached?
    When I attach my solution the sketch for the tread will be on the XY plane.
    The extrusion for the belt will initially be a surface body and then Thicken after the Pattern of the treads.
    Member
    01-11-2013 08:07 AM in reply to: mklassen78
    That is why im on this forum, It will not allow me to pattern and keep tangency, It just gives an error. The lugs i want to pattern are in the file though.
    *Expert Elite*
    01-11-2013 08:33 AM in reply to: mklassen78
    mklassen78 wrote:
    .... It just gives an error.
    Post screen shot of error.
    *Expert Elite*
    01-11-2013 09:07 AM in reply to: JDMather
    I experimented with this one a bit more.
    It is going to be a bit more work than I originally thought.
    Because the tread cleats bend around the curves - my attempt would be with patterned-trimmed surfaces, thicken and trim again.
