Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Rubber Track Design
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Trying to model a track but i have it in more of a triangular orientation then an ovel like this sample picture. Any advice on how to pattern the tread and inner lug around any shape i desire? I have tried making an extrusion on one of the flat faces and then patterning it around but it keeps the lug in the same orientation and does not follow the contour nicely. Any advice for me
Re: Rubber Track Design
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You can do rectangular pattern in part enviroment along choosen curve, and set orientation to direction1. This should work.
I hope that's what you're looking for.
Greg
Some old workstation ...
Fancy HP LCD
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
mklassen78 wrote:Trying to model a track but i have it in more of a triangular orientation . Any advice for me?
See this document pg 16
http://home.pct.edu/~jmather/SkillsUSA%20Universit
Inventor Professional 2014 Edu 64-bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you for your replies! JDMather that does work to pattern around and i can get it to follow the contour i want but it leaves a gap between the "treads" as it is patterned around a curve. It does not keep tangent. Any solution to that?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Attach your ipt file here.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hope this helps more
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I don't see a pattern in the file you attached?
When I attach my solution the sketch for the tread will be on the XY plane.
The extrusion for the belt will initially be a surface body and then Thicken after the Pattern of the treads.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
That is why im on this forum, It will not allow me to pattern and keep tangency, It just gives an error. The lugs i want to pattern are in the file though.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
mklassen78 wrote:.... It just gives an error.
Post screen shot of error.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I experimented with this one a bit more.
It is going to be a bit more work than I originally thought.
Because the tread cleats bend around the curves - my attempt would be with patterned-trimmed surfaces, thicken and trim again.
