• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Berger, Barclay
    Rotating Parts in Assembly
    148 Views, 2 Replies
    12-13-2002 06:41 AM
    When rotating a part in an assembly how do you constrain it to 90 degree's?
    Doesn't seem to want to do exactly 90, thought shift or alt would do it but
    doesn't.
    Please use plain text.
    *Gwin, Hal
    Re: Rotating Parts in Assembly
    12-13-2002 07:13 AM in reply to: *Berger, Barclay
    If you are using the Rotate Component tool on the Assembly toolbar, I don't
    know of any way to precisely control the rotation. You could use an Angle
    constraint to another part or an origin plane. That would allow you to
    accurately control the angle.
    Hal Gwin
    Mechanical Designer
    Xenogen
    Active Contributor
    12-17-2002 06:01 AM in reply to: *Berger, Barclay
    See the other helpful thread in this NG about Orienting an assembly to an axis. It also contains other useful hints to control what you are trying to do. It worked for me...I posted the question!
