• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Rotated spline becomes unusable
    130 Views, 3 Replies
    01-14-2013 03:25 PM
    I have a spline that runs through about 70 points to make the perfect line. But when I rotate the scketch the spline turned from green to black and is no longer recognised as a boundry. I then have to delete the black line and re-draw. What is going wrong? How do I keep the spline green and usable?
    Please use plain text.
    Re: Rotated spline becomes unusable
    01-14-2013 04:12 PM in reply to: vance4c
    Why are you rotating the sketch?
    Did you turn it into a Sketch Block first?
    Can you attach the *.ipt file here?
    New Member
    01-28-2013 01:33 PM in reply to: vance4c
    I am rotating the part because the part in the design rotates and I need measurments at every degree of rotation. So I rotate the sketch make my measuremets and then rotate again.
    No it is not a sketch block.
    No I can not upload the ipt file it has sensitive design that I am not aloud to show.
    01-28-2013 03:12 PM in reply to: vance4c
    Problem doesn't make sense to me without at least a picture, but my guess is that turning into a Sketch Block might solve the problem.
