• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Re: Ribs on curved surface/ trimming to complex surface
    03-05-2013 06:48 AM in reply to: swhite
    Can you attach an example that is associative.
    I have always used the Thicken/Offset surface zero.
    Checking to see of there is any reason to change.
    Please use plain text.
    Distinguished Contributor
    03-05-2013 06:59 AM in reply to: JDMather
    Well, it appears they have removed any ability to make them associative. It used to be a simple matter why I brought it up. It appears they have diasabled that feature in at least the 2011 version. In 2010 it was a simple and easy and worked well. If this is the case an extrusion of the face as you said may be the best idea.
    This is too bad as it was a handy and quick feature in 2010. One could set it as associative and forget it without having extra extrusions even if only tenths of a thousand thick. They could at least have removed the check box if they are no longer going to make it an option.
    Steven White
    Lee C. Moore, Inc.
    www.lcm-wci.com
    Inventor 2011
    Intel Dual Xeon E31225 @ 3.1 GHz CPU
    16 GB RAM
    NVIDIA Quadro 600 GPU
    Windows 7 - 64 Bit
    03-05-2013 07:30 AM in reply to: swhite
    I don't think I ever said "extrusion of the face" and don't know how that would be done.
    I think the only time the Associative is avialable is when editing a part within the context of an assembly and Copy Object from another part into the current part.
    I have no idea why it isn't possible within a single part file.  Seems to me that would be a short way of Thicken/Offset as zero.
    Curtis_Waguespack
    03-05-2013 07:48 AM in reply to: JDMather
    Hi JDMather,
    I think your're spot on. Also in context of an assembly you're only able to make it associative if using the surface or composite option, the solid option will not be associative.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
