• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Ribbon menu justified to right
    257 Views, 10 Replies
    10-22-2011 03:18 AM
    Hi
    I have switched computers from my laptop to my workstation.  My laptop has an Nvidia card FX2500M, and my workstation has an ATI Fire V5600.
    I work with the ribbon minimised to tabs.  On my laptop, when I click a tab the ribbon opens directly below the tab (i.e. justified to the left of the screen); but on my workstation, the ribbon opens below the tab but justified to the right of the screen.  This means I have to move the cursor back and forth across the screen.
    Is there a Reg setting to change the justified back to the left of the screen?
    When the ribbon minimise is on other settings (e.g. minimise to panel tiles) the ribbon is justified to the left side of the screen.
    Personally, I think its an easter egg from one of those wierd left handed people - like my wife!!! :smileyhappy:
    Inventor Pro 2012 with SP1.
    Cheers, Neil.
    Please use plain text.
    Product Support
    Re: Ribbon menu justified to right
    10-24-2011 07:19 AM in reply to: NeilClasby75
    To see where the justification was set to. In the ribbon menu at the end in a gray area (no tabs) or anywhere in the ribbon. RMB and select the Ribbon Appearence and see that it set to Normal and Docking Position, TOP. Check that before (if you haven't)  we look at the registry.
    Valued Contributor
    10-25-2011 12:30 AM in reply to: mercerc
    Yes, I checked and it is set to 'top'.
    Valued Contributor
    10-27-2011 12:27 AM in reply to: mercerc
    Hi
    Have you got any suggestions on the registry to try?
    I have no issues with editing the registry.  I did this before when I suddenly had the original interface in 2012, and had to switch it to the ribbon.
    CHeers, Neil.
    Valued Contributor
    01-04-2012 02:31 AM in reply to: NeilClasby75
    I have just updated my laptop to Windows 7.  I have a Nvidia Quadro 2800M card.
    I have been using this setup for a few days with no problem, but I was just changing the pre-highlight settings (turn off) and Optimized selection (changed time to 1.0 sec).  Suddenly my minimised ribbon is now justified to the right of the screen again (like I had on my main workstation - also Windows 7, but with FireGL card).
    I have tried putting settings back but menu is still justified to right.
    This is a real problem as it slows my work flow down considerably.
    You help would be greatly appreciated.
    Regards, Neil.
    Valued Contributor
    01-04-2012 02:52 AM in reply to: NeilClasby75
    Here is a PDF screenshot.
    Valued Contributor
    01-22-2012 10:19 AM in reply to: NeilClasby75
    Anybody got a solution?
    *Expert Elite*
    blair
    01-22-2012 10:29 PM in reply to: NeilClasby75
    Try cycling the Menu around, Top, Left, Right and back to Top and see if that fixes it.
    Never seen a Menu with RH justification.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    Valued Contributor
    01-23-2012 02:23 AM in reply to: blair
    Hi
    Just tried cycling the options.  I did this with the ribbon in each minimise option, then each location, but it didn't sort it.
    I also noticed the reset to default, but that didn't sort it either.
    Help!
    Valued Contributor
    01-26-2012 03:45 AM in reply to: NeilClasby75
    Any more suggestions from Autodesk?
    Maybe some Registry values to tweak?
    Cheers, Neil.
