• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Revision table description justification
    196 Views, 10 Replies
    07-13-2009 05:19 AM
    is there a way to set the justification to left in the revision table justification? I've tried playing with the formats and I can't get it to do anything but be centred.
    Please use plain text.
    *Dennis Jeffrey
    Re: Revision table description justification
    07-13-2009 06:04 AM in reply to: johnny01
    You need to edit the annotation style BEFORE you use it - 2010.
    Dennis Jeffrey, Autodesk Inventor Certified Expert
    Autodesk Manufacturing Implementation Certified Expert.
    Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
    AIP 2008 SP3, AIP 2009-SP2, IV2010 ProPcCillin AV
    AMD 64 x2 3.0 Ghz, 8GB RAM GeForce 9800GT 512MB
    XP Pro SP3, XP Pro64 SP2, Windows XP Silver Theme
    http://teknigroup.com
    07-13-2009 07:16 AM in reply to: johnny01
    I tried that and still didn't work. Could it be a problem in my template file since I have already created a revision table? Do I need to start a new template file with no revision table?
    *Dennis Jeffrey
    07-13-2009 07:30 AM in reply to: johnny01
    Yes. What version of IV?
    07-13-2009 07:39 AM in reply to: johnny01
    2009
    Valued Mentor
    07-13-2009 08:33 AM in reply to: johnny01
    If you select the table, can't you just select the style in the pulldown? Try switch to a different style then back if just clicking the current style doesn't update it. (I don't have any drawings yet in my current project so I'm not checking if this works.)
    07-13-2009 08:36 AM in reply to: johnny01
    I tried that and it didn't update.
    Valued Mentor
    07-13-2009 08:52 AM in reply to: johnny01
    Place a new one with the new style then copy and paste the entries. That's all you can do. Everything else works that way but not the rev table, I remember now.
    Distinguished Contributor
    07-13-2009 12:30 PM in reply to: johnny01
    When opening the format how are you doing it? To make achange you need to go to the format dir and open from there. That could be part of your problem. Rather than the open format pulldown.
    msk
    12-04-2012 09:58 PM in reply to: johnny01
    I am using IV2013.  I am attempting to insert a revision table in some drawings created around 2005 or before.  I find that the Description column in the revisiion table is centered justified both in the Heading and in the Comments.  I want the comments to be left justified.  So I go to Edit Revision Table Style and right click on the Description column and set the Value to right justified.  Save.  The value is still center justified.  I used to be able to do this in prior releases.  What is wrong?
