• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Mentor
    Re: Revision Table for old drawings
    12-11-2012 01:47 PM in reply to: dan_inv09
    You can click the add revision row(s) icon multiple times, it will give you a new row and a new revision number.
    John Retzlaff
    Please use plain text.
    *Expert Elite*
    Curtis_Waguespack
    12-11-2012 01:57 PM in reply to: dan_inv09
    Hi dan_inv09,
    dan_inv09 wrote:
    ... when were they added?
    Inventor version 11 or Inventor 2008 maybe? :smileywink:
    edit: it looks like it was Inventor 2008
    Jamie keeps all of the what's new here: http://inventortopix.blogspot.com/p/whats-new-docs.html
    dan_inv09 wrote:
    As far as changing the rev level in the iProperties, when you "Add Revision Row" or "Add Revision Row(s)" does it go to 4? I think you will find that it will give you a 3.
     Indeed it will increment off of an internally stored number that we can't access, so you're correct it would go to 3 again.
    dan_inv09 wrote:
    ("Add Revision Row(s)" gave me a little false hope with the "(s)". Doesn't that make you think it would let you do more than one at a time?)
    You can add multiple rows using Add Revision Row(s) the button in the dialog, by clicking it multiple times.
    Then you could select the intermediate rows and right-click, and then choose Visible in order to toggle off their visibility:
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Valued Mentor
    12-11-2012 01:57 PM in reply to: john.retzlaff
    I was exiting the dialog and right clicking, I honestly must have had like a blind spot or something. I did not see those and/or was absolutely certain they were not what I was looking for when I was trying to figure out a better way to do what I was doing.
    I think "(s)" implies that you can do many with one click - you don't need it to say that you are allowed to click it again, do you?
