• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Mentor
    Revision Table for old drawings
    141 Views, 12 Replies
    12-11-2012 12:16 PM
    I am redrawing an old drawing in Inventor. (This particular one is very new compared to some of the ones I need to do, it was started in 1979.)
    If I "Insert Row" within the revision table dialog I have to manually type in the rev number.
    And then if I do a "Add Revision Row" it will give the next number from the last "Add Revision Row".
    This "redrawn" revision is going to be number 10, what is the proper workflow for putting all these revisions on a new drawing?
    (I also have some drawings that are 10 or 15 years older that are what I will call "more active" that I will be converting along with this one.)
    Please use plain text.
    Valued Mentor
    Re: Revision Table for old drawings
    12-11-2012 12:49 PM in reply to: dan_inv09
    It also keeps the tally separate from the iProperties, I thought if I changed it there then I would be able to add rows within the table, but the next "Add Revision Row" indexed from the last "Add Revision Row" not the number in the iProperties.
    Distinguished Mentor
    12-11-2012 12:50 PM in reply to: dan_inv09
    Are you entering all the previous revisions and descriptions?
    Sounds like what you described should be fine, just insert your revision table rows and type in the description and date.
    The only row that will update from the iProperties is the last one added.
    John Retzlaff
    *Expert Elite*
    Curtis_Waguespack
    12-11-2012 01:00 PM in reply to: dan_inv09
    Hi dan_inv09,
    It seems to work the way you want if you're placing a new rev table
    You might need to delete your existing rev table and place another and ensure the start number is what you want.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Valued Mentor
    12-11-2012 01:04 PM in reply to: john.retzlaff
    It doesn't appear to me to be updating from the iProperties, it updates from the last "Add Revision Row"
    Valued Mentor
    12-11-2012 01:09 PM in reply to: Curtis_Waguespack
    I would really rather not throw away all the history, but I kind of figured that would have to be the AutoDesk approved workflow.
    12-11-2012 01:14 PM in reply to: dan_inv09
    The last row added will pull in whatever is in Comments field in Summary tab, the revision date will pull from Eng. Approved Date from Status tab in iProperties.
    John Retzlaff
    Valued Mentor
    12-11-2012 01:23 PM in reply to: john.retzlaff
    I meant the revision number. When I changed the revision number in the iProperties then did a "Add Revision Row" it did not index from that number.
    And I never really understood that: so you click "Add Revision Row" and it brings up the revision table dialog - then you have to close that out without doing anything and go to iProperties to do the editing?
    *Expert Elite*
    Curtis_Waguespack
    12-11-2012 01:29 PM in reply to: dan_inv09
    Hi dan_inv09,
    There's an iProperties button in the Revision Table edit dialog that will open the iProperties dialog and allow you to manually enter the iProperty. The Rev# from the iProperty is then pulled into the current row.
    Here I've used the button to step into the iProperties dialog and change the next row from 2 to 3, and it's pulled into the table.
    I hope this helps.
    Curtis
    Valued Mentor
    12-11-2012 01:41 PM in reply to: Curtis_Waguespack
    See, this is why you ask questions. I never noticed those there - when were they added?
    As far as changing the rev level in the iProperties, when you "Add Revision Row" or "Add Revision Row(s)" does it go to 4? I think you will find that it will give you a 3.
    ("Add Revision Row(s)" gave me a little false hope with the "(s)". Doesn't that make you think it would let you do more than one at a time?)
