• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    mbus0013
    Resolve link - reference to file error
    260 Views, 1 Replies
    06-25-2012 12:46 AM
    I have created parts made up of a smaller parts themselves, them multiple assemblies of different parts that are all used in a final asembly. Now I need to give this whole assembly to someone.  I tried sending all the files together with the assembly. However, when the receiver tried to open the assembly, most of the file references could not be resolved and inventor asked for the path of each, which would take too long to do.
    Is there any way around this?
    Please use plain text.
    Active Contributor
    Re: Resolve link - reference to file error
    06-25-2012 01:36 AM in reply to: mbus0013
    Yes.
    It's called a Pack and Go.
    Open the master assembly and than on the drop down menu where you can find the save and save as....click on save as and there you can find pack and go. Here you can select a destination folder and include all reference files. When all setings are done. Click start.
    It will automaticaly copy all files that are referenced in this master assembly and even create a project file to. This is what you need to pass on if you want to be sure that you will pass on a working model.
    Inventor 2010
    Win 7 64-bit
    Dell Precision T5400
    Intel Xeon 2,5 GHz
    8 Gb RAM
    NVIDIA Quadro Fx 3700
