• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    rmerlob
    Reset face color overrides?
    208 Views, 2 Replies
    12-20-2011 06:10 AM
    Theres still not a way to reset all face´s color to ´´as feature´´? I can only seem to find old threads with no solution.
    I really dont want to control click every surface someone before me manually changed, mb some VBA code ?
    RM
    Please use plain text.
    Curtis_Waguespack
    Re: Reset face color overrides?
    12-20-2011 08:35 AM in reply to: rmerlob
    Hi rmerlob,
    If you are using Inventor 2010 or later, you can expand the Solid Bodies folder in the browser and then right-click on the body and choose Properties. There you can set the color to As Part or to a specific color, and then use the Strip Overides button to reset any color overrides present.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Valued Contributor
    rmerlob
    12-20-2011 08:58 AM in reply to: Curtis_Waguespack
    Wow, thanks.
    Really.
