However that is bad practice (Re-orient assembly) as it skews ALL views,
not just the isomentric. Personally, I would not annotate ( place balloons)
until I had the desired view. Reorientation of the ISO view prior to
placement is not that hard, and can be done from the IDW prior to placement.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr.
AIP 2008 SP2, AIP 2009 PcCillin AV
HP zv5000 AMD64 2GB
Geforce Go 440, Driver: .8185
XP Pro SP2, Windows XP Silver Theme
http://teknigroup.com
"Andrew Faix (Autodesk)"
wrote in message
news:6014849@discussion.autodesk.com...
If it's a drawing view of an assembly, you can re-orient the assembly with
respect to the assembly origin work geometry (and I THINK this would trickle
down to your presentation file, but I haven't tried it). Specifically,
unground your base component, and reconstrain as necessary to the origin
planes.
Otherwise, yes, you have to delete and recreate the view.
-Andrew Faix
Product Design Lead
Inventor Core Applications
wrote in message news:6014810@discussion.autodesk.com...
I know I can change the orientation before a view is placed. But, I gather
that that a view cannot be changed after it is placed. And if I want a view
with the part or asm at a slightly different angle, I have to "start over"
from scratch. This is inconvient if I have an exploded assembly ipn with 100
parts and I need the ipn tweaked a few degrees to better show parts. So, if
I understand the limitations of inventor, I have to delete the current view,
reorient the ipn, place the new view of the ipn, and redo the 100 ballons?
Steve
IV11 sp4
