• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Rick Donnellon
    Rendering Surfaces?
    186 Views, 3 Replies
    05-20-2007 09:47 PM
    Can this be done? I have some complex parts I imported as surfaces and when
    I do a render the parts disappeared.
    TIA
    Rick
    Please use plain text.
    *MarcoA
    Re: Rendering Surfaces?
    05-21-2007 12:12 AM in reply to: *Rick Donnellon
    > and when I do a render the parts disappeared.
    It can be done.
    RMB on the surfaces to select a color.
    In attachment there is a simple rendering of 2 surfaces.
    M.
    05-21-2007 05:33 AM in reply to: *Rick Donnellon
    Can you zip and post the files?
    Why not convert to solids?
    Did you turn off translucency of the surfaces?
    Inventor Professional 2014 Edu 64-bit
    *Rick Donnellon
    05-21-2007 02:34 PM in reply to: *Rick Donnellon
    Its a Adept i600 robot I downloaded (Link below). I've tried to stitch and
    convert to solids but with my limited experience, have not be able to
    convert to solids. Also to make matters worse my customer requires r10
    models. In r10 color can be applied to surfaces as mentioned in another
    reply and then they will render but r10 does not have this capibility.
    http://www.adept.com/support/downloads.asp?docid=500007
    fourcanet
    wrote in message news:5592178@discussion.autodesk.com...
