• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    GregDobson5029
    Rendering Problems
    334 Views, 1 Replies
    09-03-2010 08:26 PM
    I am having trouble within the Studio when rendering an animation.
    Software:  Inventor Professional 2011, SP1 with rendering fix
    Hardware:  Dell T7400, 32GB RAM, Quadro 4800, Win 7 Pro
    Animation is 52.5sec long
    Problem 1:  Inventor crashes immediately when trying to render
                          frames with the "Entire Production" selected under
                         Time Range on Output tab.  Other settings: 800x600,
                         High AntiAliasing, 24 fps, True Reflection
    Problems 2: When I try to use "Specified Time Range" within the
                             Time Range area, I can not enter a value greater
                             than 30.0 sec in the second time text box
    Any ideas?
    Product Support
    Re: Rendering Problems
    09-08-2010 02:18 PM in reply to: GregDobson5029
    In order to help us resolve this, please attach a system information file in its native (nfo) format using the following as a guide:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7491145&linkID=9240817
    Also, please provide a compressed file of a pack and go of the assembly. The settings you described may be pushing the limits of the machine and the only way to really tell will be to get the nfo and files. Have you tried this using lower resolution and a lower rate of fps? What are the results if you do?
    Thank you.
    Daren Lawrence
    Product Support Specialist
    MFG Support - Inventor
    http://beinginventive.typepad.com/being-inventive/
