• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    andrew.cox
    Renaming sheets in a multi-sheet IDW....
    245 Views, 5 Replies
    10-04-2012 12:04 PM
    Is there any easy way to have sheet name automatically pull the "description" iProperty from the part that is on the sheet?  It can be very handy in a multi-sheet drawing for each sheet to have a descripive name in the browser, but the only way to do this (that I know of) is to manually change it.
    Andrew
    Please use plain text.
    Curtis_Waguespack
    Re: Renaming sheets in a multi-sheet IDW....
    10-04-2012 01:21 PM in reply to: andrew.cox
    Hi andrew.cox,
    Here's an iLogic rule to do this. Note that description might not write to the sheet name correctly if it has characters such as commas in it.
    I hope this helps.
    Curtis
    Dim oSheets As Sheets
    oSheets = ThisDoc.Document.sheets
    Dim oSheet As Sheet
    For Each oSheet In oSheets
    	oSheet.activate
    	Dim oDrawingView As DrawingView
    	oDrawingView = oSheet.DrawingViews(1)
    	oModelName = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument.DisplayName
    	oDesc = iProperties.Value(oModelName, "Project", "Description")
    	oSheet.Name =  oDesc
    Next
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Member
    andrew.cox
    10-05-2012 05:55 AM in reply to: Curtis_Waguespack
    Hi Curtis,
    Thanks for this info!  However, I have not even used iLogic, so I don't know what to do with this.  Any chance you could point me towards a good tutorial, or provide me instructions yourself?
    Cheers,
    Andrew
    Curtis_Waguespack
    10-05-2012 08:38 AM in reply to: andrew.cox
    Hi andrew.cox,
    This should cover it:
    http://inventortrenches.blogspot.com/2012/01/creating-basic-ilogic-rule-with-event.html
    I hope this helps.
    Curtis
    Member
    andrew.cox
    10-05-2012 12:30 PM in reply to: Curtis_Waguespack
    Hi Curtis,
    I'm having some trouble with the code you supplied.  When I enter in into the "rule", I get this error....
    I cut-and-paste the code exactly as you had it in your previous post.  Any thoughts?
    Andrew
    Curtis_Waguespack
    10-08-2012 07:12 AM in reply to: andrew.cox
    Hi andrew.cox,
    Most likely there is an issue with a line wrap due to this forums formatting, or something like that. Attached is the rule in a text file, you can copy and paste from it.
    If you see the same results post back.
    I hope this helps.
    Curtis
