• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Cook, Gary
    Renaming files using DA vs ren command
    45 Views, 2 Replies
    11-05-2002 10:17 AM
    Fumbling along trying to use DA to rename a bunch of files, and wondering if
    I'm missing something. Basically, I used pack'n'go to copy a project with
    all the files beginning with the prefix 217 to a new folder.
    I wanted to use DA to rename the many files to use a 272 prefix, but found
    it very tedious. Instead, I used the Win2K CMD shell and used the ren
    commnad "ren 217*.* 272*.*"
    Presto. You have to nurse the assembly upon first opening, but it seems
    light years faster than using DA. But, like I said, perhaps I'm missing
    something. Any feedback from more enlightened users?
    Thanks.
    Please use plain text.
    *Dotson, Sean
    Re: Renaming files using DA vs ren command
    11-05-2002 10:55 AM in reply to: *Cook, Gary
    In this situation I'd do what you did. However for complex project
    structures (especially in a shared environment) things aren't always so
    simple.
    Sean Dotson
    Inventor Tutorials and More
    http://www.sdotson.com
    remove all #s from email to send
    "Gary Cook" <1gcook2@3comautotech4.com (remove #s)> wrote in message
    news:5754690BCEB0A2B62679F399D3CB4612@in.WebX.maYIadrTaRb...
    if
    > Thanks.
    *Hintehoeller, Richard
    11-05-2002 08:50 PM in reply to: *Cook, Gary
    Gary:
    The only downside to this approach that I can think of is that the
    Properties>Project>Part Number will not pick up the change.
    When you generate the Bill of Materials, you may be picking up this
    property and it will show the obsolete value.
    Otherwise, it certainly is the quickest way I've come across for
    accomplishing your goal.
    Richard
