• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Removing characters from iProperty
    133 Views, 4 Replies
    01-03-2013 02:47 PM
    I'd like to build a rule into my standard part template that takes the part number (which it automatically gets from the rilename by default), removes the characters after a delimiter, as well as the delimiter itself, and sets that as a new custom property. For example, we'll call the custom property Prop1
    For part 123-321-1.ipt
    Inventor already sets part number iProperty to 123-321-1
    I want to set Prop1 to 123-321
    For part 123-321-25.ipt
    Inventor already sets part number iProperty to 123-321-25
    Any ideas?
    Please use plain text.
    Employee
    Re: Removing characters from iProperty
    01-03-2013 09:51 PM in reply to: drguitarum2005
    Assumed that there is one custom property named "Prop1" in the template, and please use the code lines below in your iLogic rule -
    Temp=Split(iProperties.Value("Project", "Part Number"),"-")(UBound(Split(iProperties.Value("Project", "Part Number"),"-")))
    iProperties.Value("Custom", "Prop1")=Left(iProperties.Value("Project", "Part Number"),Len(iProperties.Value("Project", "Part Number"))-Len(temp)-1)
    River Cai
    Quality Assurance Team
    Valued Contributor
    01-04-2013 06:48 AM in reply to: Yijiang.Cai
    Thanks for the help sir, I was able to take that, modify it a little, and get it to work on my template.
    My problem now is, I have this rule running after save document. When I saved the template, it ran the rule and set the property. Now when I create a new part with that template, it still has the Prop1 value from the template, not from the new part. How do I make it overwrite the value again?
    Valued Contributor
    01-04-2013 06:50 AM in reply to: drguitarum2005
    Ignore that, dumb question. Changed it to "before save" it works fine.
    Thanks!
    Employee
    01-04-2013 06:03 PM in reply to: drguitarum2005
    Really glad to know this could be helpful for you:smileyvery-happy:
    River Cai
