• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Re: Remove Ordinate dimension
    01-09-2013 02:29 PM in reply to: *Diane Hawes \(Autodesk\)
    Is there a way to show an ordinate indicator after you have hidden it?
    Please use plain text.
    Curtis_Waguespack
    01-09-2013 02:33 PM in reply to: bhahn
    Hi bhahn,
    You can right-click on one of the ordinate dimensions and deselect Hide Origin Indicator from the list.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
