• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Remove Item from BoM but not Assembly
    80 Views, 3 Replies
    02-13-2013 12:30 AM
    Good Morning All,
    First of all I apologise in advance if this question has already been asked. I had a look and couldn't find anything relevant.
    I have a drawing in which I need to keep a part in the assembly but I don't want to display it on the BoM. Is there any way I can remove it from the BoM without removing it from the assembly and drawing?
    Many thanks.
    Chris
    Please use plain text.
    cbenner
    Re: Remove Item from BoM but not Assembly
    02-13-2013 04:58 AM in reply to: Chris86542
    Well, one way I think would be to set the item to "Reference" in your BOM.  Then it will not show in the parts list on your drawing.
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
    Valued Contributor
    bstewart
    If you're referring to the drawing Parts List, you can double-click the parts list, highlight the row you want to hide, right-click the row and click Visible.
    HTH
    Bob
    ____________________________________________________
    Product Design Suite Ultimate 2012 (SP2) | Vault 2012 (Update 2)
    Dell Precision M6600 | Intel i7-2820QM - 16GB
    nVIDIA Quadro 4000M | Windows 7/64 Pro
    *Pro
    02-13-2013 05:04 AM in reply to: Chris86542
    Change it to Reference.  Right click on the component in the assembly (.iam) and select iProperties.  On the Occurrence tab change the BOM Structure from Default (Normal) to Reference.  In your drawing this will also change the linestyle to phantom, but you can edit the drawing view(s) and change the way Reference components are displayed.
    You can also make this change in the BOM editor instead of the iProperties box.
    Sam B
    Inventor 2012 Certified Professional
    Please click "Accept as Solution" if this response answers your question.
    Inventor Professional 2013 SP1.1 Update 1
    Windows XP Pro 32-bit, SP3
    HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
    SpaceExplorer/SpaceNavigator NB, driver 3.7.18
    still waiting for a foreshortened radius dimensioning tool in Drawing Manager
