• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Referencing parts in assembly
    115 Views, 2 Replies
    01-18-2013 03:51 AM
    I have a rather complex assembly that I didn't draft but I am trying to work with. Most of my experience is with Solidworks. I'm trying to create a hole in a plate that lines up with a hole in a different part in the same assembly. I know there is probably a way to create the hole in the assembly and reference the other part but I dont know how. Any help?
    Crev64
    Autodesk Inventor 2009
    Please use plain text.
    Active Contributor
    Re: Referencing parts in assembly
    01-18-2013 05:29 AM in reply to: crev64
    I can get the hole drawn in the assmebly, but when I open the part the hole doesnt exist. Is there anyway to fix that?
    Crev64
    *Pro
    01-18-2013 05:55 AM in reply to: crev64
    From the assembly, edit (not open) the part that needs the hole, start a sketch, project the hole from the part that already has it, then use that hole center for your hole command.  This makes the part Adaptive, which maintains a link through that assembly to the other part.
    Hope that gets you started.
    Sam B
    Inventor 2012 Certified Professional
    Please click "Accept as Solution" if this response answers your question.
    Inventor Professional 2013 SP1.1 Update 1
    Windows XP Pro 32-bit, SP3
    HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
    SpaceExplorer/SpaceNavigator NB, driver 3.7.18
    still waiting for a foreshortened radius dimensioning tool in Drawing Manager
