• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Expert Elite*
    mrattray
    Reference parameter measuring between two parts in an assembly
    92 Views, 3 Replies
    07-31-2012 06:52 AM
    I need to assign the dimension in my screenshot to a parameter so I can use it to drive another assembly. However, I can't find any way to capture it in a usable manner.
    In the screenshot I have an associative part inserted that contains only a sketch with the projected line and point that I wish to measure between, but the geometery in the sketch does not update when the model geometery changes. This seems to be normal behaviour?
    Can anyone shed some light on what I'm doing wrong here or suggest another method?
    Thanks in advance,
    Mike (not Matt) Rattray
    Please use plain text.
    *Expert Elite*
    Re: Reference parameter measuring between two parts in an assembly
    07-31-2012 11:34 AM in reply to: mrattray
    It would seem logical to do it the way you have done because you don't know what you need till you get to the point you are at, I have done it myself and found the same problem.
    It will definitely need an assembly update at least but this may not be enough and to fully force a recalc you would need a rebuild all.
    Would a sketch in the assembly help, rather than in another part? not sure just a guess.
    I think it's the reference that's the problem and needs a full rebuild for Inventor to work out the result.
    If you could, possibly another option would be a master sketch part to control geometry and propagate up through to other parts and assemblies.
    This would push dimensions out rather than pull them in.
    Not what you want to hear when you've got so far.
    *Expert Elite*
    mrattray
    07-31-2012 12:43 PM in reply to: harco
    I've ried every variation of update, rebuild, punch it in the kidney I can think of.
    I'm a lot further then what's shown in that screen cap, way to far to change the entire modeling strategy.
    What I'm really trying to do here is calculate the needed length of the incline section to get to a given discharge height. I'm triging out the length of the hypotenuse and am using a reference parameter from a part to know how much to subtract for the concave (lower curved piece). Now I'm tying to get a parameter from the head (top curvy piece) so my program knows exactly how long the incline needs to be.
    *Expert Elite*
    07-31-2012 02:13 PM in reply to: mrattray
    Yeah, I thought that, practically finished but then you need last piece of the puzzle, bummer!.
    Can you use the piece that the projected edges come from to hold the reference then you would only have 2 parts with one projection across parts.
    I'm guessing that the sketch part having refs from 2 separate parts might be confusing things, not sure, just trying to throw ideas you way.
    Would creating feature from the point and line in the ref part force a calculation, guessing again.
    From what you say about the concave section that the method seems to work there ok, so should work at the top too, doubly annoying!
    Sorry I can't be more help.
