• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Reference Drawing Sheet Number with iLogic
    209 Views, 5 Replies
    12-11-2012 12:01 PM
    Does anyone know how to reference the drawign sheet number using iLogic?  I see on the snippets on the side a way to reference the sheet name, but I only want the number.  To get the name it is ActiveSheet.Name, but ActiveSheet.Number does not work.  Getting the name give something like ASSM:1, so if there was a way to take that and subtract the colon and everything before it that would work also.  I am not a programmer, I've just taked some programs I found online and modified them a little to do what I want to do, but this is holding me back a bit.
    Overall, I'm trying to modify the drawing view label to have a project number, referenced from the drawign iProperties, a view label, and sheet number, and then save that info in an iproperty of the part, and then reference that in the BOM so it automatically labels all of the views and fills out a column of the BOM to reference which page and view to find the parts of the assembly.  I have everything working except for the sheet number.
    I would greatly appreciate any help.
    Jeremy
    Please use plain text.
    Curtis_Waguespack
    Re: Reference Drawing Sheet Number with iLogic
    12-11-2012 12:36 PM in reply to: jestes
    Hi jestes,
    Here is an example:
    Dim oSheet As Sheet
    Dim SheetNumber as String
    i = 1
    For Each oSheet In ThisApplication.ActiveDocument.Sheets
    SheetNumber  = Mid(oSheet.Name, InStr(1, oSheet.Name, ":") + 1)
    MessageBox.Show(SheetNumber, oSheet.Name)
    i=1+1
    Next
    Or something like this to get the active sheet only:
    oDoc = ThisDoc.Document
    SheetNumber  = Mid(oDoc.ActiveSheet.Name, InStr(1, oDoc.ActiveSheet.Name, ":") + 1)
    MessageBox.Show(SheetNumber, oDoc.ActiveSheet.Name)
    Keep in mind you might have better luck searching and asking questions of this type on the Inventor Customization forum:
    http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Member
    12-11-2012 01:27 PM in reply to: Curtis_Waguespack
    Thanks Curtis, that worked great.  I think this will help us out a lot.
    Jeremy
    Member
    12-12-2012 08:32 AM in reply to: jestes
    Hey Curis, I found a problem in my code I was hoping you could help me with again.  For some reason what I'm doing does not work with any parts made by the frame generator.  Everything else I've tried seems to work well.  What I want is to get a project number-view label-sheet number sent to the Status iPropertie of the part or assembly that is inside the view.  Then I can use the Status iProperty inside my view label and the BOM.  I'll attach my code below.  If you wouldn't mind looking at it I would appreciate it.  Thanks a lot, I appreciate the help.
    Jeremy
    'start of ilogic codeDim oDoc As DrawingDocument:  oDoc = ThisDoc.Document
    Dim oSheets As Sheets
    Dim oSheet As Sheet
    Dim oViews As DrawingViews
    Dim oView As DrawingView
    Dim SheetNumber As String
    i =1
    oSheets = oDoc.Sheets
    For Each oSheet In oSheets
    oViews = oSheet.DrawingViews
                    For Each oView In oViews
                    'capture the current view label
    ViewLabel = oView.Name oModelName = _ oView.ReferencedDocumentDescriptor.ReferencedDocument.DisplayName Try SheetNumber =Mid(oSheet.Name, InStr(1, oSheet.Name, ":") + 1) i=1+1 iProperties.Value(oModelName, "Status", "Status") = _
    iProperties.Value("Project", "Project")+"-"+ViewLabel+SheetNumber 'Send view label items to models Status iProperty
    'Use Status iProperty for view label
    Catch 'do nothing if error
    End Try 'End If
    Next Next 'end of ilogic code
    Curtis_Waguespack
    12-12-2012 09:12 AM in reply to: jestes
    Hi jestes,
    The problem is with the display name of the Frame Generator parts (and many other Content Center parts). Basically Autodesk is setting the display name as an override in their Content Center tables, and therefore your code was reading in something such as ANSI 2x2x3_16 00000009 rather then ANSI 2x2x3_16 00000009.ipt.
    Adding a line of code to reset the display name to nothing, allows the part to return back to the default display name.
    oView.ReferencedDocumentDescriptor.ReferencedDocument.DisplayName = ""
    This is the same as doing this:
    Here's your updated rule.
    Dim oSheet As Sheet
    i =1
    		'reset the display name
    		'get the display name
    		oModelName = _
    		Try
    		'get the sheet number
    		i=1+1
    		Catch
    		End Try
    	Next
    Next
    'end of ilogic code
     I hope this helps.
    Curtis
    Member
    12-12-2012 02:04 PM in reply to: Curtis_Waguespack
    Thanks Curtis,
    That fixed that, but I did run into a couple more issues.  Is there any way to make it work with iParts?  I get an error if there is an iPart on the sheet.  I might have to use a different iProperty other than Status to work with iParts because I don't see that as being on that you can update in the iPart table.  If this is not doable or very difficult I can just update these views manually.  It seems to still work for the rest of the views.
    Also, for some reason it works fine on 2 of the machines I tried it on, but it won't work on one of our other employees machines.  It doesn't give any errors, and as far as I know it runs the program, but it just doesn't do anything.  No changes to the properties.  Any idea why it would be different on one machine?  I have the rule saved in a template, so we're both opening the exact same thing and both on Inventor 2013.  I don't think he has the newest service pack installed, so that might be it.
    Thanks for the help, I really appreciate it.
    Jeremy
