• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    Distinguished Contributor
    Reference Dimensions
    228 Views, 10 Replies
    09-09-2003 12:04 PM
    In 5.3 I can create reference dimensions in sketch mode to my hearts content. They became very valuable as I would use them to determine placement of multiple features. Now, in IV 7, I have alot of trouble creating reference dimensions from adjacent features on the same surface. I have to change the way I'm working now and it has stumped me on a few occasions. Does anyone else have issues with this and is there a "new" feature I need to enable or is this the cost of progress?
    *Zander, Quinn
    Re: Reference Dimensions
    09-09-2003 12:28 PM in reply to: deckart
    Dennis,
    Cost of progress. I assume you already noticed that the equal constraint
    is has only about 20% the functionality as it did a few releases ago.
    This reference dimension thing has continually given me a sore neck from
    me cocking my head sideways and asking the monitor what the $&%@ it
    thinks it is doing.
    Sometimes you can force them.
    Take a normal dim that affects the driven dim's placement and change it
    to driven. Place a normal dim where you want the driven dim. Force this
    normal dim to a driven dim via the styles pulldown, then change the
    driven dim (that used to be a normal dim) back to a normal dim.
    I was going to do a mockery of the "Single Day Productivity" slogan, but
    decided against it.
    QBZ
    "deckart" wrote in message
    news:f188b86.-1@WebX.maYIadrTaRb...
    Re:
    09-11-2003 06:15 AM in reply to: deckart
    Come on Autodesk! You just took the idea of "parametrics" and threw it out. I just want to create a reference dimension to drive another feature! You know... parametrically! IV5.3 had basically no problem performing this operation. Now it's "Failed to create linear dimension". It will not give me a simple dimension! Are we going backwords here?
    Member
    VeeGee
    Re: Re:
    02-08-2012 03:31 PM in reply to: deckart
    Even now, Inventor 2010 doesn't seem to be able to use a reference dimension in an equation.
    Distinguished Mentor
    Re: Re:
    02-09-2012 04:23 AM in reply to: VeeGee
    Post a part that illustrates the problem.  I've never had a problem using driven dimensions in an equation.
    Sam B
    Inventor 2012 Certified Professional
    Please click "Accept as Solution" if this response answers your question.
    Inventor Professional 2012 SP1
    Windows XP Pro 32-bit, SP3
    HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
    SpaceExplorer/SpaceNavigator NB, driver 3.7.18
    still waiting for a foreshortened radius dimensioning tool
    ****Sage
    Re: Re:
    02-09-2012 04:33 AM in reply to: VeeGee
    Works fine here.
    I don't remember a time when it didn't?
    Autodesk Inventor Certified Professional
    Inventor Professional 2012 Edu 32-bit
    Still waiting for -Draft option on any Rib feature. -Properties Painter.
    Still wondering why Edit Form is above Edit Feature on RMB?
    Member
    VeeGee
    Re: Re:
    02-09-2012 11:52 AM in reply to: JDMather
    You can see the values are used for the existing dimension and replacing the values with the reference dims causes there error. A cyclical constraint dependency was detected.
    Member
    VeeGee
    02-09-2012 12:01 PM in reply to: deckart
    Must not have selected add attachment after selecting.
    ****Sage
    02-09-2012 12:12 PM in reply to: VeeGee
    Spoiler
    Post ipt file here - I am not familiar with interrogating image files to find logic errors.
    Member
    VeeGee
    02-09-2012 09:03 PM in reply to: JDMather
    I take it you didn't bother looking.
