• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Reading Solidworks 2012 files into Inventor
    992 Views, 6 Replies
    09-03-2012 05:08 AM
    We are using Inventor 2012 and would like to read Solidworks 2012 files directly into the system. This can be done with Solidworks 2011 files but our vendor upgraded his software between the time he sent us test files to try  the import and now. Can you tell me if the is a plug in or something that will allow us to read SW 2012 files or should we upgrade to Inventor 2013?
    Please use plain text.
    Re: Reading Solidworks 2012 files into Inventor
    09-03-2012 05:36 AM in reply to: sdeboer
    SolidWorks 2012 was released after Inventor 2012.  You will need a later version of Inventor, perhaps free Inventor Fusion 2013.
    http://labs.autodesk.com
    Inventor Professional 2014 Edu 64-bit
    Valued Mentor
    CelticDesignServices
    09-03-2012 04:40 PM in reply to: sdeboer
    If I'm not mistaken, if you have the latest Service Pack loaded for Inventor 2012, that should allow you to open SW 2012 files.
    I'm pretty sure that's what I've seen in the past.
    Jim
    Celtic Design Services, LLC
    Inventor/AutoCAD/Vault WorkGroups
    Always for hire - celticdesign01ATyahooDOTcom
    http://www.linkedin.com/pub/celticdesignservices-llc/51/610/398/
    Please use the Accept as Solution and Give Kudos functions as appropriate to further enhance the value of these forums.
    Go raibh maith agat (in other words...Thank you!)
    Employee
    09-03-2012 08:13 PM in reply to: CelticDesignServices
    The latest service package for Inventor 2012 is SP2 and it is not supported to open Solidworks 2012 files :smileysad:.
    Inventor 2013 does supports to read Solidworks 2012 files.
    Thanks for the post and maybe the information for this topic post on somewhere is wrong, can you tell me where you had seen it ? We will correct the information if possible.
    Have a nice day !!!
    Kevin Li
    Quality Assurance Team
    Active Member
    09-05-2012 07:55 AM in reply to: sdeboer
    We loaded 2013 on a test machine and it works.
    Now we have to schedule our upgrade to 2013. A little sooner than I would like though.
    Thanks for all your help
    Employee
    09-05-2012 07:01 PM in reply to: sdeboer
    Hi sdeboer,
    Glad to see it works.
    If you meet any other issues about Inventor data translation, please post in this forum or directly contact me via email: Hongyuan.Li@autodesk.com , we will follow up.
    Have a nice day !!!
    Kevin Li
    *Pro
    sbixler
    09-06-2012 07:10 AM in reply to: sdeboer
    If you're not ready to move to Inventor 2013, just use it to open the Solidworks files, then save them to STEP format for use in 2012.  They are dumb solds coming into 2013, so you won't lose anything by STEPing them into 2012.
