• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    *Chasek, Jerry
    Read Only Project/ Workgroup Files?
    40 Views, 4 Replies
    11-13-2002 04:00 AM
    When I try to open a file or save a file I get this "Error Locking File". It
    shows that project is read only and I have file open in another application,
    but I don't have another file open. However I had the file crash yesterday
    and I opened the file up while it was crashed. It still thinks the file is
    open. I have went into properties and checked to see if it was read only and
    it was so I checked it off, but it doesn't help even after a restart. How do
    I get this read only problem fixed?
    Jerry
    Please use plain text.
    *Keller, Kent
    Re: Read Only Project/ Workgroup Files?
    11-13-2002 04:48 AM in reply to: *Chasek, Jerry
    Go into task manager and see if you see a instance of Inventor running in the process tab.
    Kill it....unless of course you have one open on purpose
    Kent
    Member of the Autodesk Discussion Forum Moderator Program
    "Jerry Chasek" wrote in message
    news:3B1D15783F5FA79160C7AFA095E398CB@in.WebX.maYIadrTaRb...
    > Jerry
    *Chasek, Jerry
    Re:
    11-13-2002 05:06 AM in reply to: *Chasek, Jerry
    Nothing else is running in the task manager.
    "Kent Keller" wrote in message
    news:70F1C6E8642559C94B4FBDE50CD541AA@in.WebX.maYIadrTaRb...
    the process tab.
    > Kent
    File". It
    application,
    yesterday
    is
    and
    How do
    > > Jerry
    *Keller, Kent
    Re:
    11-13-2002 05:27 AM in reply to: *Chasek, Jerry
    news:3AF3DB75DB0CDE1A5F4ACE51A0DE0006@in.WebX.maYIadrTaRb...
    Can you post the file to customer files?
    Kent
    *Keller, Kent
    Re:
    11-13-2002 11:01 PM in reply to: *Chasek, Jerry
    Jerry
    Don't know why I didn't think of this before. In Windows explorer make
    sure in ....Tools.....Folder Options.....View tab, make sure you have "Show
    hidden files and folders" checked. Then maybe you will see a file with a
    .lck or something like that extension. Try renaming it or moving it out of
    the folder and seeing if that helps.
    Kent Keller
    http://www.MyMcad.com/KWiK/Mcad.htm
    news:6FFF80EE05084DEDA27C7EAF36084289@in.WebX.maYIadrTaRb...
    > Kent
