• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Re-Sizable Panel
    90 Views, 1 Replies
    11-12-2012 07:33 AM
    I was hoping someone could help me with the following issue.
    I would like to make a aluminum framed panel template that I can enter in the height and width dimensions and then save the panel assembly into it's own unique part#. Right now, when I design enclosure, I will have multiple sizes of framed panel and I typically have to manually change the length and width dimensions for the individual extrusion members, then change the panel size manually. I re-name the new extrusions and panels to avoid file name conflicts. Is there a way to simplify the process?
    Like I said before, I will have multiple "section"(SEC) assemblies in each main assembly file.
    I attached a zip file with my aluminum framed panel assembly.
    Please use plain text.
    *Expert Elite*
    PaulMunford
    Re: Re-Sizable Panel
    11-12-2012 01:37 PM in reply to: jbauer
    Look into skeletal modelling:
    http://cadsetterout.com/inventor-tutorials/assembly-techniques-for-woodworkers-the-skeletal-modellin...
    or iCopy:
    http://cadsetterout.com/inventor-tutorials/autodesk-inventor-icopy-tutorial/
    Copying an Inventor assembly has it's wn challenges. There's some good advice here:
    http://cadsetterout.com/inventor-tutorials/the-secrets-of-copying-assembly-files/
    Let us know how you get on!
    Paul
    The CAD Setter Out Blog
    @CadSetterOut
    Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
