• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Ray tracing wont work
    433 Views, 11 Replies
    08-22-2012 03:24 PM
    So I've been using ray the realistic view with ray tracing enabled for a while now for quick renders, but I recently had to reinstall Windows and now it wont work. I've installed all of my drivers and everything is up to date, but when I click on ray tracing it starts to do it for a couple of seconds then just disables. After that first try whenever I click the button it simply wont enable. Any idea on how I can fix this problem?
    Please use plain text.
    Employee
    Xun.Zhang
    Re: Ray tracing wont work
    08-26-2012 11:36 PM in reply to: zcohenld
    Hi Zcohenld,
    It's hard to identify the reason for the raytracing issue, could you provide more information? such as:
    1. Your OS
    2. Your Grapich Card and other hardware information
    3. Dataset for rendering
    4. A video for the issue
    My suggestion is reinstall Graphic card diver for the first step, if it make no sense, Pleae try to reinstall Inventor for further step.
    Xun Zhang
    Software QA Engineer
    Inventor Quality Assurance Team
    Autodesk, Inc.
    *Expert Elite*
    blair
    08-26-2012 11:52 PM in reply to: zcohenld
    Do a un-install of your graphics card drivers first before you try do the re-install.
    Check your systems: Performance Information and Tools from the Control Panel. Also with Inventor open and a model open within Inventor run the hardware test and see what hardware level you get.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 320.18
    SpacePilot Pro 3.16.3 / 6.16.1 / 4.11
    Employee
    Xun.Zhang
    08-27-2012 12:22 AM in reply to: zcohenld
    Hi Zcohenld,
    One more comments, please try to update the driver of your Graphic card first.
    Xun Zhang
    Autodesk, Inc.
    Member
    08-31-2012 03:58 PM in reply to: Xun.Zhang
    Sorry about the delay in a response.
    Running Windows 7 32bit
    AMD Phenom 9850 quad core (2.5GHz)
    GTX480
    4 GB ram
    Below is a video of the problem.
    http://youtu.be/usqYLX4XDEw
    I tried reinstalling both Inventor and my graphics drivers. Both did not fix the problem.
    *Expert Elite*
    blair
    08-31-2012 04:23 PM in reply to: zcohenld
    You didn't give the hardware level from with Inventor.
    I would guess that you may have a voltage problem with your card. These cards require additional power supply cable to be plugged into them, should something happen they will drop back to a minimum level.
    Win7-64
    Member
    08-31-2012 07:36 PM in reply to: blair
    Sorry, but what do you mean by the hardware level for Inventor?
    And the power to my video card is fine. As I said in my first post, everything used to work, its just when I reinstalled my OS it stopped. I havent changed the wiring at all since then. Anyway, I have the video card powered not only by the PCIe but by the extra power cables as well, and my PSU can handle the full pull of the video card and processor at the same time (850watt)
    *Expert Elite*
    blair
    08-31-2012 11:14 PM in reply to: zcohenld
    The "Performance Information and Tools" is run from the Windows system: Start>Control Panel>Performance Information and Tools: give us the numbers
    The Hardware Assemement level is run within Inventor. Open Inventor, open a model, the open the Tools>Options> Applications Tab>Hardware>Dianostic: it will give a Feature Level
    While you are at this screen try using the different settings: Quality, Performance, Compatibilty and Software praphics
    Win7-64
    Member
    09-01-2012 06:36 AM in reply to: blair
    Processor--7.1
    Memory--7.2
    Graphics--7.9
    Gaming graphics--7.9
    Primary hard disk--5.9
    Inventor was set to Performance, changing any of the settings didn't fix the problem.
    Below are the diagnostics from Inventor as well if you needed it.
    This Direct3D graphics driver is Microsoft WHQL certified
    Graphics Hardware Description:
    NVIDIA GeForce GTX 480
    AIRViz Device Manager \ VirtualDeviceDx11
    Feature Level 5_0
    Quality Mode
    Hardware Renderer
    Graphics driver file nvd3dum.dll,nvwgf2um.dll,nvwgf2um.dll is version 8.17.13.142
    Current optimization settings are not known
    The display is using 32-bit color
    Inventor Version:
    Build: 138, Release: 2013 RTM - Date: Thu 03/01/2012
    32-Bit Edition - 2.00 GB
    Loaded Inventor Add-Ins:
    Assembly Bonus Tools
    Simulation: Dynamic Simulation
    Simulation: Frame Analysis
    iCopy
    System Information:
    Operating System: 32-bit Microsoft Windows 7 Professional (Build 7601) Service Pack 1
    Language: English
    System Manufacturer: Gigabyte Technology Co., Ltd.
    System Model: GA-MA790FX-UD5P
    BIOS: Award Modular BIOS v6.00PG
    Processor: AMD Phenom(tm) 9850 Quad-Core Processor (1 processor, 4 cores)
    System Memory: 3.116 GB RAM
    Graphics Device Information:
    Renderer: HAL
    Manufacturer: NVIDIA
    Chip Type: GeForce GTX 480
    DAC Type: Integrated RAMDAC
    Graphics HW Memory: 1.454 GB
    Display Mode: 1920 x 1200 (32 bit) (59 Hz)
    Graphics driver file: nvd3dum.dll,nvwgf2um.dll,nvwgf2um.dll
    Driver file version: 8.17.13.142
    Driver Date: 15 May 2012 0:00:00 UTC (Coordinated Universal Time)
    Direct3D Graphics Device Information:
    Adapter Description: NVIDIA GeForce GTX 480
    Vendor ID string: 0x000010de
    Device ID string: 0x000006c0
    VendorID: 10de
    DeviceID: 6c0
    SubSystemID: 75f10de
    Revision: a3
    Direct3D 10 / DXGI System Information:
    Dedicated Video Memory: 1.454 GB
    Dedicated System Memory: 0 MB
    Shared System Memory: 1.308 GB
    DxDiag System Information:
    Operating System: Windows 7 Professional 32-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120330-1504)
    Language: English (Regional Setting: English)
    Processor: AMD Phenom(tm) 9850 Quad-Core Processor (4 CPUs), ~2.5GHz
    System Memory: 4096MB RAM
    Page File: 3899MB used, 2480MB available
    DirectX Version: DirectX 11
    DxDiag Version: 6.01.7601.17514
    DxDiag Graphics Device Information:
    DirectX Version: 10.0
    DDI Version: 11
    DDI Version Number: b
    DxDiag WHQL Level: 0
    Driver Signed Valid: True
    Driver Signed: True
    Revision:
    Graphics HW Memory: 2827 MB
    Display Mode: 1920 x 1200 (32 bit) (59Hz)
    Driver file version: 8.17.0013.0142
    Driver Date: 5/15/2012 06:26:00
    WHQL Level: 1
    Inventor Options Information:
    Options = 0x00000000
    Warning Options = 0x00000000
    Graphics driver log information:
    Thank you for bearing with me as I get all the information you need.
    *Expert Elite*
    blair
    09-01-2012 08:52 AM in reply to: zcohenld
    Everything looks fine, you should be able to run Ray-Tracing without a problem.
    Win7-64
