• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Ray Tracing not applying shadows or lighting correctly.
    142 Views, 1 Replies
    10-10-2012 01:29 AM
    Just started having a play with ray tracing in Inventor 2013 Pro & I'm quite impressed how quickly you can get a rendered view of a model. However, it seems no matter how I set up the lighting or the shadows in the 'Settings' menu when I click on 'Tay Tracing' it seems to default back to some original settings. The shadows & lighting in any of the drop down menus don't seem to be applied. eg. I select 'Two Lights' from the menu, then select 'Settings' I then adjust the shadows & the lights from within the menu. It all looks good on the screen & click Ray Tracing & everything that I've done doesn't get applied? However, when I cancel & stop the Ray Tracing the shadows & Lights are still there. Am I doing something wrong or missing something? Cheers
    Please use plain text.
    New Member
    Re: Ray Tracing not applying shadows or lighting correctly.
    10-11-2012 06:06 AM in reply to: cmberry20
    I´ve exactly the same problem..(nice to here that i´m not alone).....
    An explanation would be nice....thanks...
