Autodesk Inventor
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
*Rory
Query regarding getting IGES files from Delcam into Inventor 9
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
85 Views, 8 Replies
11-11-2004 08:04 AM
Hopefully someone in here will have already gone through this....
One of our customers designs plastic molded parts using IV9, they get the
tooling for these parts made by a toolmaker who uses Delcam.
The problem is, they design the parts "square" and let the toolmaker decide
how the mold should be split, and how to draft the model.
So basically, the toolmaker does all the face drafting and then sends them
back a completed model, in IGES format.
The problem comes when trying to get these IGES files into Inventor.
In Delcam, the model is complete and watertight, in IV, the model will not
stitich into a solid (some simple ones will but more complex ones will not)
Delcam has a lot of options when creating IGES files so my question is :-
Has anyone here got "optimum" settings for Delcam which give a clean IGES
file which will then work well in Inventor 9?
I realise that IGES is a file format which is best avoided but unfortunately
it's the only current option. Hopefully we can tweak the Delcam output to
make it as clean as possible.
Thanks for any advice anyone can offer (apart from "Sell the toolmaker a
copy of Inventor"!)
Cheers
Rory
*John Bilton
Re: Query regarding getting IGES files from Delcam into Inventor 9
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-11-2004 08:20 AM in reply to:
*Rory
Hi Rory, a few tips Len Newman gave me years ago for dealing with dirty IGES files.
Bring them into MDT but slacken off the system tolerance a bit (1 or 2 dp), and untick the Entity Validation option on the
Miscellaneous tab or the IGESIN Options.
If this brings it in clean to MDT, you can then IGESOUT again to bring into Inventor. You might want to drop the IGES version back
to 5.0 and even save trimmed surfaces as bounded surfaces.
Welcome to the dark world of IGES translation...
John Bilton
*Rory
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-11-2004 08:44 AM in reply to:
*Rory
"John Bilton" wrote in message
news:419391fd$1_2@newsprd01...
IGES files.
John,
I don't know about "welcome to", IGES files have been a pain in my **** for
the last 8 years!
I sometimes miss the days when all I used to do was design in AutoCAD and
not have to worry about fixing 3D files and problems.
But then I think, "do I really want to be using AutoCAD instead of
Inventor?"
I think you can guess the answer!
Cheers for the advice by the way, I'll give it a go.
Rory
p.s - If Inventor could actually create drawing views of surfaces I wouldn't
need to bother with this (hint hint Autodesk!)
*Duncan Anderson
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-11-2004 08:55 AM in reply to:
*Rory
John,
The figures you give, are they inclusive of using the IGES.opt file or do you have your own options file ? If so, would you be
prepared to share it ?
Duncan
"Humour ... is one man shouting gibberish in the face of authority, and proving by fabricated insanity that nothing could be as mad
as what passes for ordinary living."
(Terence 'Spike' Milligan K.B.E., 1918-2002)
"John Bilton" wrote in message news:419391fd$1_2@newsprd01...
> back
> John Bilton
*Jeff Howard
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-11-2004 09:22 AM in reply to:
*Rory
> Delcam which give a clean IGES file which
> avoided but unfortunately it's the only current option.
I don't know about Delcam specifically, but assuming the surfaces have been
stitched into a "solid"; probably the best bet is to export as Type 186
BRep and IGESIN to MDT (options: make sure 186 is mapped to solid or part
and, maybe, check IGES Tolerance (GP19)). A solid is usually the result.
Repair if necessary. Export from MDT as ACIS or STEP to feed IV.
> ...(apart from "Sell the toolmaker a
> copy of Inventor"!)
Bet you couldn't give him one. Maybe some day IV may have some real data
translation capabilities.
Attached is a simple test IGES. Maybe IV9 will import as a solid, v6
won't. If not maybe someone can explain why.
*Madhan Selvaraj \(Autodesk\)
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-11-2004 02:03 PM in reply to:
*Rory
Jeff - IV9 does import the bath001.igs file as a solid. IV8 imports it as a
solid too - however, it does not automatically promote due to some errors in
the model. Is it what you are seeing in IV6?
Madhan
"Jeff Howard" wrote in message
news:4193a074_2@newsprd01...
been
> > copy of Inventor"!)
*Jeff Howard
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-11-2004 08:38 PM in reply to:
*Rory
Madhan Selvaraj wrote ...
> IV8 imports it as a solid too - however, it does not
Hello, Madhan.
IV6's behavior depends on the import options used.
Healer on, Auto stitch and promote on; see attached jpg. This is what I
tried before posting. If later versions will heal without destroying the
model, that's progress.
Healer off, Auto stitch and promote on; construction mode analysis
indicates a closed quilt (all "good" edges) which can then be promoted to a
solid. (With the usual "quality" error message. It's been my experience
that few "foreign" models other than very simple blocky parts will come in
without generating the message unless healed first.)
Healer off, Auto stitch and promote off; same as above.
Re "due to some errors in the model": I'll assume you mean "errors in
translation", as the model can be imported as a solid unassisted and
shelled to a thickness of 25 - 50 inches in a couple of other programs I
tried it in. If that's a "dirty" file it doesn't seem to bother them.
Thanks for taking a look.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-12-2004 02:45 PM in reply to:
*Rory
Hi Jeff,
Thanks for the information. Like I mentioned in my previous message, INV9
imports this as a solid without damaging the model. I was also able to
create some drawing views. However, shelling operation to a thickness of
25-50 inches failed. We will investigate into this.
By "errors in the model", I meant "the translated model does not pass
Inventor quality check" which does not necessarily mean there were errors in
translation because during translation, there is only a certain limit we can
go to automatically heal the data in order to not-damage the original
intention of the data.
-Madhan
news:41943d61_2@newsprd01...
> Hello, Madhan.
a
*Jeff Howard
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-12-2004 03:08 PM in reply to:
*Rory
Gotcha. Thanks again.
