• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Quadro or Gaming card for Inventor?
    573 Views, 17 Replies
    08-08-2012 05:58 PM
    Some people suggested me to get a gaming card such as the GTX590 instead of the Quadro 4000 or 5000. The reason is that "It's my understanding that since Inventor moved away from OpenGL to DirectX, workstation cards aren't really a necessity like they used to be."
    Is this true? Given a choice, which of the above cards would you chooce?
    Please use plain text.
    Distinguished Mentor
    Re: Quadro or Gaming card for Inventor?
    08-08-2012 06:39 PM in reply to: hajimeml
    Correct, we run professional cards but there is no need these days. Go for value for money and get a top end gaming card such as the GTX590.
    Please mark as "Accept as Solution" if it answers your question or "Kudos" if you found it useful.
    Stew, AICP
    Inventor Professional 2013, Autodesk Simulation Multiphysics 2013
    Windows 7 x64 Core i7 32GB Ram FX2000
    Valued Contributor
    08-08-2012 07:13 PM in reply to: Inv_kaos
    Which is the highest performance card? Silency is an important factor.
    *Expert Elite*
    blair
    08-08-2012 10:07 PM in reply to: hajimeml
    We used to run Quadro cards, but have now switched to fast "gaming" cards. Either the Nvidia or AMD cards work fine. We have gone with the EVGA cards, if you register their product within the set period, their warranties are quite long. If someone is willing to stand behind their product for a long period of time, you would guess their build quality is good along with used components.
    Google search for graphic card ratings, there are a number of sites that test the card.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    Valued Mentor
    mpatchus
    08-09-2012 03:48 AM in reply to: hajimeml
    Make sure that your workstations support the gaming cards.  We have found that our Lenovo workstations won't utilize the gaming cards.
    Mike Patchus
    Inventor 2012 SP1
    Vault Pro 2013
    *Expert Elite*
    08-09-2012 05:44 AM in reply to: mpatchus
    huh? why.. never heard/seen that before.
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
    Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
    Valued Mentor
    mpatchus
    08-09-2012 06:30 AM in reply to: mcgyvr
    We tried putting a GeForce GTX580 into one of our Lenovo D20 Workstations and the bios had a fit.
    Contacted Lenovo and were told that the D20s were not compatible with the gaming cards, only with the Nvidia Quadro  cards.
    We tried the same test on another D20 with an AMD Radeon 6870 card and had the same results.
    First I've heard of such a thing either.  ???
    Mike Patchus
    Inventor 2012 SP1
    Vault Pro 2013
    *Pro
    08-09-2012 06:37 AM in reply to: mcgyvr
    Not sure what mpatchus is referring to, but I've got a GTX 560Ti in an HP Z600, and there's not sufficient power taps available-- the Z600 power supply has only one 6-pin PCI power connector, and only one available Molex 12 V peripheral power connector.  The 560Ti needs two 6-pin power connectors (one of which can be supplied by two Molex connectors).
    The 560Ti works, but it doesn't have all the power available that it needs, on a workstation with a 600W power supply!
    *Expert Elite*
    sam_m
    08-09-2012 06:50 AM in reply to: mpatchus
    what psu has it got tho?  Only reason I can think for any pc to be "incompatible" with a gpu (assuming it's the correct slot on the motherboard).
    googling "Lenovo D20 geforce" gives the link below - shows that gaming cards do work on the system, so can only imagine the problem was the psu-demands of the higher-end gaming cards.
    http://forums.lenovo.com/t5/ThinkStation/ThinkStation-D20-and-graphics-card-with-power-cables/td-p/6...
    Please mark this response as "Accept as Solution" if it answers your question - but note that the solution may not be the answer you're wanting to hear...
    Lithium - helping nntp users with mania, depression and headaches
    08-09-2012 07:28 AM in reply to: Inv_kaos
    I was beginning to wonder about gaming cards.  Good to know.
    First question would be, do they still work OK with AutoCAD?
    Second question, is the new hot CAD system going to be a good gaming computer instead of a "workstation?"
    (NOTE:  If trains stop at train stations, what happens at a workstation?)
    Bill Schmid
    Autodesk Product Design Suite Premium 2013
    Autodesk Vault Professional 2013
    Dell Precision T1650
    Windows 7 Professional SP1 64-bit
    Intel E3-1270 V2 3.5GHz / 16G RAM
    Nvidia Quadro 2000, Driver 276.42
    256 GB SSD
    Space Navigator, Driver Version 6.16.1
