• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    Member
    Pure tortion
    180 Views, 4 Replies
    11-06-2012 12:59 PM
    Why in pure tortion of a round beam one diameter increases in size. In theory it shouldn't. I just put a torque on one side and fixed constrained another end.  Is this due to the way, how inventor solves it? Is there a way to minimize it?
    Please use plain text.
    Valued Contributor
    Re: Pure tortion
    11-06-2012 01:27 PM in reply to: SNOWV
    This thread provides a good explanation:
    https://forum.solidworks.com/thread/39134
    https://forum.solidworks.com/servlet/JiveServlet/download/192901-60523/expansion.png
    Basically, it's just an artifact of Inventor's scaling methods.  Displacement scaling is not equivalent to increasing the torque on the part.
    -Autodesk Inventor Professional 2012
    Member
    Re: Pure tortion
    11-06-2012 09:51 PM in reply to: nannerdw
    I saw that post, but it still count's as not answered. Is there a way to minimize this effect and can I believe stress results?
    karthur1
    Re: Pure tortion
    11-07-2012 05:31 AM in reply to: SNOWV
    In "theory" are you saying that the shaft diameter should not expand?  What theory are you using?
    If you are having a problem with the way Inventor displays this, you can change the scaling to "Undeformed" if you don't want to see the deformation.
    Kirk A.
    Windows 7 x64 -12 GB Ram
    Intel i7-930 @ 3.60ghz
    nVidia GTS 250 -1GB (Driver 301.42)
    INV Pro R2013, SP1.1
    Vault Basic 2013
    Member
    Re: Pure tortion
    11-07-2012 06:31 AM in reply to: SNOWV
    Well, that is the definition of pure torsion. In theory of pure tortion, each cross section along z axis is exposed to the same momentum and deplanation doesn't occure.
    Well, now I think that Inventor does it in reality, not theoretically.
