• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Projects: style library settings in 2012?
    423 Views, 4 Replies
    04-26-2011 07:27 PM
    Just noticed  'use style library = No?' no longer exists in 2012 only 'read only' and 'read-write' are come uo when you RMB 'use style library' in the Projects dialog, is this correct or have I made an error during installation?
    Thanks, Mick
    Employee
    Re: Projects: style library settings in 2012?
    04-26-2011 07:58 PM in reply to: grinderz
    It was removed by us in 2012 because it has been useless in the recent Inventor releases.
    Marshal
    Marshal Tu
    Sr SW Engineer
    MFG
    05-26-2011 06:38 AM in reply to: marshaltu
    We do not use projects at my company. How do I get that annoying message from poping up whenever I create a new drawing? The only way I found to do it in the past was to set the Use Styles Library = No.
    Mike Eck
    Senior Designer/ CAD Programmer
    Howden North America
    Using Inventor 2013
    Employee
    05-26-2011 06:22 PM in reply to: meck
    I suppose the annoying message you mentions is "Style Conflict" dialog. If so, please open your drawing template and save copy as new template. You can delete the old template and use the new one to new drawing files.
    If it cannot solve your issue, you can just suppress the dialog by hitting the "Prompts" in this dialog.
    Marshal
    Marshal Tu
    Sr SW Engineer
    MFG
    New Member
    Exodusrasta
    02-09-2012 04:18 AM in reply to: grinderz
    this 2012 sucks!
    I cant work with my old styles and I do not have time to create a new .idw with all my options!
    In future versions put the option NO actived again please.
