Autodesk Inventor
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
*Singlehurst, Rob
Project Cut Edges. Associativ e or Not??
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
57 Views, 5 Replies
11-11-2002 12:49 AM
I'm creating a part sketch by using the Project Cut Edges command. Looking
in the help it says this is associative i.e. if I change the parent geometry
the cut edges will update. Is this correct or not as it doesn't appear to
be working for me.
I know in 5.3 it wasn't associative so is it just the help files being a bit
too hopeful
Cheers,
--Rob Singlehurst
be working for me.
too hopeful
Cheers,
--Rob Singlehurst
*Fulford, Drew
Re: Project Cut Edges. Associativ e or Not??
Options
- Highlight
- Email to a Friend
11-11-2002 12:58 AM in reply to:
*Singlehurst, Rob
Not
Drew Fulford B.A.Sc. Systems Engineer
Solid Caddgroup Inc. Burlington, Ontario
Tel: (905)331-9670, Fax: (905)331-7280
Corporate: http://www.solidcadcam.com/
Member of the Autodesk Discussion Forum Moderator Program
Visit my MCAD website @ http://www.mymcad.com/
"Rob Singlehurst" wrote in message
news:63DDCC2E0CCFA32084E85E1A1C8B426E@in.WebX.maYI adrTaRb...
Looking
geometry
> be working for me.
bit
> too hopeful
> Cheers,
> --Rob Singlehurst
"Rob Singlehurst"
Looking
geometry
> be working for me.
bit
> too hopeful
> Cheers,
> --Rob Singlehurst
*Singlehurst, Rob
Re:
Options
- Highlight
- Email to a Friend
11-11-2002 01:16 AM in reply to:
*Singlehurst, Rob
Thanks Drew,
"Drew Fulford" wrote in message
news:0018890E73358512E29424F01C3C19A2@in.WebX.maYI adrTaRb...
> Not
> Looking
> geometry
to
> > be working for me.
> bit
> > too hopeful
> > Cheers,
> > --Rob Singlehurst
"Drew Fulford"
> Not
> "Rob Singlehurst"
> Looking
> geometry
to
> > be working for me.
> bit
> > too hopeful
> > Cheers,
> > --Rob Singlehurst
*Germer, Ole
Options
- Highlight
- Email to a Friend
*Singlehurst, Rob
The work around is to share sketches. Do one sketch -- extrude etc. and it
is consumed. Go back and share sketch. Now edit sketch and -- extrude etc.
or whatever and things stays associative.
By doing the sketch in two parts you prevent Dr.Error from reporting .
Ole Germer
Helping create better involute profiles for gears
http://www.geocities.com/olegermer/index.html
Looking
geometry
> be working for me.
bit
> too hopeful
> Cheers,
> --Rob Singlehurst
Ole Germer
"Rob Singlehurst"
Looking
geometry
> be working for me.
bit
> too hopeful
> Cheers,
> --Rob Singlehurst
*Howard, Jeff
Options
- Highlight
- Email to a Friend
11-11-2002 02:55 PM in reply to:
*Singlehurst, Rob
Rob, while projected cut edges aren't associative, you can get something that
might do what you want by using 3D Sketch > 3D Intersection. Use a work plane
for one of the intersecting surfaces. If you are trying to reference cut
edges of another part it requires jumping through a couple of additional
hoops, but can be done, usually requiring creating construction surfaces
(their edges can be projected "cross part" associatively, while sketch
elements cannot) or deriving the referenced part in as surfaces.
Another limitation: you can't extrude / revolve a 3D Sketch, but can get the
same thing by lofting between two sections or projecting the 3D Sketch
elements onto a 2D Sketch.
Good luck with it,
Jeff
be working for me.
too hopeful
Cheers,
--Rob Singlehurst
Good luck with it,
Jeff
"Rob Singlehurst"
be working for me.
too hopeful
Cheers,
--Rob Singlehurst
*Singlehurst, Rob
Re:
Options
- Highlight
- Email to a Friend
11-11-2002 06:52 PM in reply to:
*Singlehurst, Rob
Thanks Jeff,
I've never actually used the 3D sketches. I think I'll have a bit of a
tinker around with them at home, and see what I can come up with,
Cheers
--Rob Singlehurst
"Jeff Howard" wrote in message
news:BB0042465FD6C124565CC0B71568376F@in.WebX.maYI adrTaRb...
that
plane
the
> Good luck with it,
> Jeff
Looking
geometry
> be working for me.
bit
> too hopeful
> Cheers,
> --Rob Singlehurst
Cheers
--Rob Singlehurst
"Jeff Howard"
that
plane
the
> Good luck with it,
> Jeff
> "Rob Singlehurst"
Looking
geometry
> be working for me.
bit
> too hopeful
> Cheers,
> --Rob Singlehurst
