• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    zreed042
    Accepted Solution
    Problems with threading
    276 Views, 3 Replies
    01-12-2012 11:40 AM
    Howdy fellas. I'm designing a flashhider that fits on an airsoft gun using AutoCad Inventor and trying to print it using the 3D printing service, Shapeways. The threads on the gun are M14-1 and when I use the thread feature in Inventor all it puts on the part is a 2D texture. When I upload the model to any other software (Meshlab for example) the threads are gone. So, I downloaded a pllugin that models the threads in 3D. This fixed the problem in part, but when I upload the model to shapeways (in an .stl format) I get some weirdness.
    Here's the flash hider:
    And here's what shapeways thinks I upload:
    It somehow fills in the hole that I tapped and threaded. Is there any way to fix this?
    Please use plain text.
    *Expert Elite*
    Re: Problems with threading
    01-12-2012 11:55 AM in reply to: zreed042
    If you increase the quality of the stl file during export does it fix the problem?  When you do a save copy as to save to stl hit the options button before you save and mess with those settings..
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
    Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
    New Member
    zreed042
    01-12-2012 12:02 PM in reply to: mcgyvr
    You know what, that totally fixed the problem! (I also drew the thread manually)
    *Expert Elite*
    01-12-2012 12:36 PM in reply to: zreed042
    Also check the units when creating the stl as Inventor defaults to CM rather than document units.
