Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Problems after installati on of Service Pack 1 of Autodesk Inventor 2012
- Highlight
- Email to a Friend
After installing the Service Pack 1 of Autodesk Inventor 2012, shortcut keys like M (Measure Tool), Ctrl+0 (Clean Screen) has stopped working. Dimensions are not placed automatically during line, arc,etc creation.
Please help me in solving this problem?
Thanks in advance.
Nisheeth Srivastava
Inventor 3-D Parametric Solid Model Drawing (Video Tutorials)
Re: Problems after installati on of Service Pack 1 of Autodesk Inventor 2012
- Highlight
- Email to a Friend
Try right clicking gray area of ribbon, customize user commands, Keyboard tab, button Reset All Keys.
For dimensions, check Application Options, Sketch tab, check your settings under Heads Up Display.
- Highlight
- Email to a Friend
John Retzlaff
After applying your suggestion Ctrl+0, Ctrl+S started working but M (Measure Tool), L (Line tool ) F7 ( slice graphic) shortcuts are still not working. Dynamic Input is appearing in the window, but to understand the my problem watch the video below
Regards
Nisheeth Srivastava
- Highlight
- Email to a Friend
Go into the Inventor application options and turn on the settings you see in the attached picture. When you try the shortcuts it will show what ones are available when you type. My guess is there are now more shortcuts that start with the same letter as the ones you are using. If there are multiple that start with L in order to fire off the line command you will need to remove all others that start with L in that environment or hit the enter or spacebar after typing L to fire off the cammand. Hope this helps.
Corey Parks
IV2012 Factory Design Suite Ultimate 64bit
Includes: Inventor Professional, AutoCAD Architecture & Navisworks Manage
Windows 7 64 bit- Synergis Adept document management software
16gb RAM --- Nvidia Quadro 4000 2gb
- Highlight
- Email to a Friend
Hello John Retzlaff,
I have reacently facing a new problem with ribon tab. While working on drawing file on ribbon pannel Annotate tab is not visible. Instead of this Annotate (ESKD) is visible. I tried reset ribbon but the problem is still the same. See the screen shot below.
How can I solve this problem?
Regards
Nisheeth Srivastava
- Highlight
- Email to a Friend
Go to Tools, Add-Ins and unload ESKD Support.
- Highlight
- Email to a Friend
Thanks a lot john.retzlaff. After applying the settings mentioned by you my problem solved.
Regards
Nisheeth Srivastava
