• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Accepted Solution
    Problem with constrain
    261 Views, 4 Replies
    11-10-2012 11:01 AM
    I am novice in Inventor and I have a little problem with consrain. I create an assembly and insert 2 parts (2 boxes). After placing they stay edge to edge as shown on figure 1. I wish them stand one over another with gap 1mm as shown on figure 2 (I moved it).
    What do I do for it? I select Constrain, as I was teached in official tutorial, then select both centers of parts sketches. I have a result, shown on figuree 3. Boxes are one into another without exact point matching. The offset parameter moves it along wrong axis. How can I get wished assembly?
    Autodesk Inventor Professional 2013 64bit on Windows 7
    Build 138
    Please use plain text.
    *Pro
    sbixler
    Re: Problem with constrain
    11-11-2012 04:05 PM in reply to: triplecorpse
    When you start the Constrain tool, it defaults to Mate-Mate.  Select one face of Part 1, then select the adjacent face of Part 2, then set your 1 mm offset.  That accomplishes one constraint.  You will need two more to remove all degrees of freedom between the two parts.
    Active Member
    11-12-2012 12:36 PM in reply to: sbixler
    You mean, I need to calculate on paper the distance between thin faces and make two more constrain with needed offset? For my simpliest work? It sounds scaring.
    I made a video, that represents my first stage. Do I make all right?
    http://www.youtube.com/watch?v=HJuw4O9c8ug
    Build 138
    *Pro
    sbixler
    11-12-2012 06:44 PM in reply to: triplecorpse
    It looks as if you made your first constraint correctly-- you now have two plates constrained so that their faces are 1mm apart.  But there are still three degrees of freedom between them: movement in two directions, and rotation.  You can prove this to yourself by dragging the ungrounded plate with your mouse.
    I don't know how you want the two plates constrained to each other, so I can't tell you how to make the others.  One typical method would be to have the centers line up.  If this is what you want, and if you modeled them centered on their respective origins, then all that is needed are two constraints between pairs of origin planes.
    If you tell us or show us how you want them aligned with each other, then we can tell you how to accomplish that.  And it does not require doing hand calculations!
    Active Member
    11-13-2012 02:32 AM in reply to: sbixler
    With some manipulations while recording video, I reached wished result :smileyhappy: I constrained two biggest planes one to another with offset by clicking them in the browser, not in viewport, and then grounded both parts. The problem is solved, thanks
    Build 138
