• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Accepted Solution
    Problem with Using Drawing feature
    89 Views, 3 Replies
    12-11-2012 04:23 PM
    I'm in grade 12 and i had to create a vending machine and i did. But the problem is when i use the drawing feature in inventor it isnt showing the whole vending machine only parts of it...
    look:
    how do i get the whole machine to show??
    Please use plain text.
    *Expert Elite*
    Re: Problem with Using Drawing feature
    12-11-2012 04:41 PM in reply to: k-m2011
    Show screen shot of the part or assembly ipt/iam or attach the files here.
    New Member
    12-11-2012 04:44 PM in reply to: JDMather
    okay i have attached it. thanks
    rhasell
    12-11-2012 05:17 PM in reply to: k-m2011
    Hi
    I have not analysed everything, but to fix your immediate issue.
    Expand the tree, find the solid body listed under "Surface Bodies", RMB and enable visibilty.
    The reason this happened was the "Delete Face" feature. This converted the solid body into a surface Body.
    Try use the Shell feature instead.
    Regards
    Reg
    Autodesk Product Design Suite Premium 2013 sp1.1 (1)
    Intel Core i7 (950@3.07GHz)
    Windows 7x64 (Home)
    12GB Ram
    Nvidia GeForce GTX 560 Ti (1Gig - Ver:314.07)
