Problem importing 3D dwg solids to Inventor
Hello
I am having a bit a troubles with importing 3D solids to Inventor.
When I make 3D solids myself with autocad 2012 it works fine, but these solids I got appear scrambled.
See image.
Hope for some good explainations 🙂
WBR
T.J.A
JDMather
Attach the original dwg file here.
Thanks for the reply
Here is an example dwg
rdyson
You have objects that are either ~100 miles or ~7km away from the origin, depending on units.
PDSU 2016
Amazing really that that was the problem.
Thanks a lot for your reply
kudos!
