• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Accepted Solution
    Problem creating iFeature....object not supported??
    383 Views, 6 Replies
    11-17-2010 01:55 AM
    I am trying to create an iFeature from some basic features but Inventor throws up the following message:
    Objects that are not supported by iFeatures will be removed from the selection
    I have uploaded the file. Can anybody please shed some light on this for me?
    I am using Inventor 2011 and Windows Vista.
    It is the last loft feature in the browser that is causing the problem.
    Andrew
    Re: Problem creating iFeature....object not supported??
    11-17-2010 03:03 AM in reply to: andrewgardner1514
    I think, the edges aren't supported.
    Active Contributor
    11-17-2010 04:24 AM in reply to: wim001
    I don't yhink I inderstand what it is that you are saying.
    11-17-2010 04:35 AM in reply to: andrewgardner1514
    Here is the ipt file.
    Active Contributor
    11-17-2010 07:32 AM in reply to: wim001
    Thanks for the help so far. Unfortunately I have still had no luck with this, I'm now having great difficulty placing the iFeature to the extent that I have invested a whole working day trying to get this to work.....it's driving me mad!
    I have switched to a revolved iFeature in an attempt to simplify things but this seems to have made the problem worse. I have attached the part file. I would like to create a revolved iFeature from the last two revolutions in the browser. I don't have a problem doing this but do not know where to include relevant work planes/axis/centre marks etc. etc. I think this is what's causing a problem when placing the iFeature. Please help!?
    The attached part contains one set of revolved features, the finished part will have identical features all over its surface, this is what I am trying to achieve by using the iFeature.
    Any further help will be much appreciated.
    Active Contributor
    11-17-2010 07:33 AM in reply to: andrewgardner1514
    Sorry, wrong part file attached above. Correct one to follow.
    Active Contributor
    11-17-2010 08:01 AM in reply to: andrewgardner1514
    Correct part now attached.
