• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    *Friedman, Aaron R.
    Probably a simple constraint problem
    60 Views, 3 Replies
    12-06-2002 03:33 AM
    I can't figure out how to constrain a 1" sphere to the sharp edge of a
    .75 dia bore.
    Aaron R. Friedman
    ARF Designs
    Please use plain text.
    *Gwin, Hal
    Re: Probably a simple constraint problem
    12-06-2002 03:41 AM in reply to: *Friedman, Aaron R.
    In your sketch, draw a construction line from the axis to the circumference,
    dimension the construction line. Finish the sketch, add a work plane by
    selecting the construction line and then an origin plane that is parallel to
    the construction line. That should create a work plane at the Ø.75 tangent,
    then just mate the axes (bore and sphere) and the plane to a face.
    Hal Gwin
    Mechanical Designer
    Xenogen
    *Friedman, Aaron R.
    Re:
    12-06-2002 04:09 AM in reply to: *Friedman, Aaron R.
    I thought it could be done simpler that that.
    thanks.
    Aaron
    > Hal Gwin
    > Mechanical Designer
    > Xenogen
    *Gwin, Hal
    Re:
    12-06-2002 05:36 AM in reply to: *Friedman, Aaron R.
    I haven't tried this, but an axes mating combined with an outside tangent
    between the sphere surface and an edge (this much I have used, but is
    unstable) and then an angular constraint between a sphere origin plane and
    another object, plane, etc. to maintain orientation.
    Hal Gwin
    Mechanical Designer
    Xenogen
