Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Print ALL drawings related to an Assembly?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Inventor (and Vault) are capable of creating and managing a BOM of the iam files and would think that it would be reltivly easy to query this bom and "find" all the associated idw files and batch print them. Possibly with the option to select the "levels" to dril down to (All, Top Level, Sub Assemblies within the iam, etc, etc)
Can anyone please help with this as I often have to print a "drawing package" for a complete build and doing this manually is very time consuming.
Thanking you in advance.
Re: Print ALL drawings related to an Assembly?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
http://www.fx64.de/produkte_index.php?lang=en&curr
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Task manager works well but not with Vault.
The design review comes with a nice batch print feature but you need to manually create batch files of .dwf files to print which need to be updated when there is a change in any assembly.
I will soon be upgrading to Vault Manufacturing from Vault 2009. Anybody know what i can expect when it comes to batch printing.
Thanx,
Ed
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Here is a code that will do this....works for me
It was posted on the Inventor Customization forum by Brendan Henderson. The idw name has to be the same as the referenced file in order for this to work.
Below is a copy of his post in case the link later fails.
Here is a macro I use that prints all of the IDW's related to an assembly. This macro is run from the assembly model. There are 4 caveats :-
1. The IDW of the assembly the macro is run from does not print (so print it manually)
2. The IDW's do not print in perfect order
3. It is coded to print to a specific printer, A3 and in landscape
4. It strips the file extension from the file name so file extensions must be visible in Windows Explorer.
Function fileExists(fname) As Boolean
If Dir(fname) <> "" Then fileExists = True Else fileExists = False
End Function
Public Sub PrintRefIDWs()
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
MsgBox "This is NOT an assembly document!", vbExclamation
Exit Sub
End If
Dim oPrintMgr As PrintManager
Set oPrintMgr = ThisApplication.ActiveDocument.PrintManager
If MsgBox("Using default printer """ & oPrintMgr.Printer & """ Do you want to continue?", vbYesNo + vbQuestion) = vbNo Then
Exit Sub
End If
Dim oDrgPrintMgr As DrawingPrintManager
MsgBox "Using printer " & oPrintMgr.Printer & ", printing 1 copy, A3 paper, landscape."
dirPath = Left(oAsmDoc.FullFileName, Len(oAsmDoc.FullFileName) - Len(oAsmDoc.DisplayName))
Dim oRefDocs As DocumentsEnumerator
Set oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
numFiles = 0
For Each oRefDoc In oRefDocs
idwPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "idw"
If fileExists(idwPathName) Then
numFiles = numFiles + 1
'If numFiles = 10 Then Exit Sub
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.Documents.Open(idwPathName, True)
oDrawDoc.Activate
Set oDrawDoc = ThisApplication.ActiveDocument
Set oDrgPrintMgr = oDrawDoc.PrintManager
oDrgPrintMgr.AllColorsAsBlack = True
oDrgPrintMgr.ScaleMode = kPrintBestFitScale
' Printer setup, default printer
oPrintMgr.ColorMode = kPrintDefaultColorMode ' Set to default
oPrintMgr.NumberOfCopies = 1 ' Set to print one copies.
oPrintMgr.Orientation = kLandscapeOrientation ' Set to print using landscape orientation.
oPrintMgr.PaperSize = kPaperSizeA3 'Set the paper size.
oPrintMgr.SubmitPrint ' Submit the print.
oDrawDoc.Close (True)
End If
Next
MsgBox "There are " & numFiles & " sent to printer."
End Sub
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You can use the Multi-sheet Plot wizard to plot multiple drawing sheets that include drawings of various sizes. You can select IDW, 2D DWF, and DWG files.
From the Start menu, click Programs
Autodesk Inventor 2012 [version]
Autodesk Multi-sheet Plot to open the Multi-sheet Plot wizard.
Application Enginner
Cadtech.Asidek | Autodesk Gold Partner
http://cadtech-asidek.blogspot.com/
www.cadtech.pt | www.cadtech.es | www.asidek.es
Autodesk Inventor Professional 2013
Windows 7 Professional 64-bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Manuela,
That is true. I have used the Multi-Sheet Plot tool several times. You still have to know what idw's you want to print, then weed through directories and add the ones you want to the list. You cant save the list, so if you want to generate the prints again, you have to go through the same routine. With this macro you dont have to do that. Here is how this works.
1. Set your default printer via Windows start menu.
2. Open an iam in Inventor.
3. Run the macro.
This will print EVERY idw that exists for all parts in this iam. I have mine set up to print to pdf's in a temp directory so I can easily bundle all the idws into a single package. This is a HUGE timesaver for me.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Fully agree with your explanation. Inventor Multi-Sheet Plot its a little poor...for example is not possible to specify in advance that A3 go to X printer and A4 goes to Z printer...and so on...
Some time ago i found Inventor Plot addin from http://www.inventortools.net/ and works very well with Inventor 2010 but unfortunately no longer works with 2012...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Would there be a way to make it search in the following directories for drawings? We don't put the drawing files in the same folder as the parts and assembly.
We usually go like this C:/Project/Job No/Part1.ipt
the drawing would be : C:/Project/Job No/Details/Part1.idw
PS: Sorry for bringing that old post up...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Not a problem bringing up this old post.
It shouldnt be a problem if you are always using the same subfolder for the details. The way this code was written it assumes that the idw is in the same location as the iam (you figured this out already). I'm sure someone here can edit one line of code and get this working for you. If not, try the customization group. Someone over there should be able to help.
Post back when you figure it out.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
