• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    wolterh6
    Presentation recording not working
    407 Views, 8 Replies
    11-25-2011 07:51 PM
    I have exploded my assembly in a presentation file, but I have not been able to record it. I have recorded videos previously, but this time the record button simply does not stay pressed. What could be the issue? I have tried recording the video as WMV and as AVI.
    Please use plain text.
    Valued Mentor
    jcneal
    Re: Presentation recording not working
    11-25-2011 09:29 PM in reply to: wolterh6
    what is your inventor version?there is hot fix for 2012.
    Active Contributor
    wolterh6
    11-25-2011 09:54 PM in reply to: jcneal
    Yes I am using Inventor 2012
    Mark_Flayler
    11-26-2011 07:48 AM in reply to: wolterh6
    Temporary Fix:
    http://blogs.rand.com/manufacturing/2011/09/empty-presentation-files-after-inventor-2012-service-pac...
    I have not seen a hotfix for this yet if you have SP1 installed.  I have not tried the Drive Constraint fix to see if that also resolves the Presentation file output.
    Mark Flayler Application Engineer - Manufacturing Solutions Division
    IMAGINiT's Manufacturing Solutions Blog:
    Active Contributor
    wolterh6
    11-26-2011 10:39 AM in reply to: Mark_Flayler
    Unfortunately the link seems to be dead.
    Valued Mentor
    jcneal
    11-26-2011 02:13 PM in reply to: wolterh6
    Active Contributor
    wolterh6
    11-27-2011 07:29 PM in reply to: jcneal
    Another dead link?
    Valued Mentor
    jcneal
    11-28-2011 08:36 AM in reply to: wolterh6
    there maybe some problems with your internet server. time to get IT department?
    anyway, try this
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17804829&linkID=9242019
    Active Contributor
    wolterh6
    11-28-2011 10:33 AM in reply to: jcneal
    Perfect, this is the hotlink for the fix. You just download the file and install it and it is fixed.
    I guess it was my server's fault :smileytongue:
