• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Precise Input toolbar
    285 Views, 5 Replies
    03-19-2012 07:07 AM
    One of my students has moved their precise input toolbar. How do I bring it back?
    Please use plain text.
    Re: Precise Input toolbar
    03-19-2012 07:29 AM in reply to: drhoads51
    Why are you using Precise Input toolbar?
    I recommend you forget you ever saw it.
    http://home.pct.edu/~jmather/skillsusa%20university.pdf
    New Member
    03-19-2012 07:37 AM in reply to: JDMather
    I'm using it because we are teaching the coordinate system and basic graphing.
    03-19-2012 08:15 AM in reply to: drhoads51
    I suspect that there might be a better technique.
    Attach the assignment here.
    You have not indicated what environment you are in or any screen shots or other information.
    Assuming 2D sketch environment - edit the sketch (or start a new sketch as appropriate).
    Start one of the sketch commands (like line).
    Click on the down arrow next to Draw (wait a minute - you did say you are using 2010 or later with Ribbon Interface?).
    You should see command for Precise Input (this can be promoted to main tab if desired).
    New Member
    12-18-2012 07:39 AM in reply to: drhoads51
    The nput fields have dissappeared from the Precise Input bar.  They worked fine yessterday.
    FYI - The reason we use the "precise input" is because it is part of the PLTW curriculum.
    12-18-2012 10:25 AM in reply to: richpark
    Whoever wrote that curriculum doesn't know what they are doing.  Find a better and more efficient technique.
    I remember my first CAD class back in '87 of the last century.  First day we were taught to use similar technique (grid).  I turned it off next day and ignored any suggestions to use it.  Never looked back.
    Post screen shot of what you are seeing with the Precise Input toolbar.
